SUSPENSION CONE COMPRESSOR TOOL
Looking for a loan of this, for a few hours. Need a metric type, for a later mini. I'm in Dublin and can collect. Keith 086 3169291
- Richmond Classics
- Whats your location?: South Mayo
- What Minis have you?: Previously owned: Classic Morris Mini Minor, Classic Mini Cooper, 1960 Classic Morris Mini Minor, Classic Mini Advantage and a fair few others and have undertaken many rebuilds.
Re: SUSPENSION CONE COMPRESSOR TOOL
Hi
If you were to fit HiLo,s, You may not need a tool to compress the cone.
Simply put the HiLo at the lowest point and you should be able to re-install without a compressor. HiLo take up all the slack as the car goes down over the years as well
Removal will be pretty easy as there is no spring left in the cone, so simply un-screw the top arm bolt, remove the pin and everything should fall away.
Neil Richmond
https://www.richmondclassicscarparts.co.uk
Neil, thanks. k.
Getting it out in the first place may be a bit difficult without one.
Have one here if it's of any use to you Keith.
Thanks Neil. I'm sorted. - i put in coil replacements.
