mini front
- stephenlovesminis
- stephenlovesminis
ok. .. i'm in the edge of my knowledge here.. *but* if you look at pics of flip-font mini's the cut along the outer wings usually follows the join with the A panel. I'm guessing you are replacing the original front with a fibre/glass "flip front" ??
the inner wings will either need strengthining or removed and replaced with structure to support the front of the subframe and the top of the dampers.
this is not a trivial operation, and it involves stuff that could really hurt you and others.
by all means go for it, but be sure about what you do!
- stephenlovesminis
front
ya i was thinking of putting on a flip front... i was talking to a friend and he said it was spot welded holding on the wings but when i went out 2day and put it on axel stands and looked in i couldn't see any welding is it pierced together or something like that?
_-_restoring mini city_-_
The spot welds are along the A panel to wing joint that runs up the body seam.This is covered by the exteral strip that runs from arch to roof.To see the welds you need to take this seam off but if your taking the wing off this seam will be coming off anyway.There are also welds along the inner wing edge,scuttle panel and front panel.Hope you have plenty of cutting and grinding disc,s.You,ll need them.
Last edited by kerryminigringo on Mon Aug 13, 2007 9:56 pm, edited 1 time in total.
- stephenlovesminis
- stephenlovesminis
Certainly and if you are fitting a flip front the inner wing will have to go and the subframe will have to be braced.I,ve only seen the end result so somebody here may have done it before.Personally I do not like them,if I needed more room I,d buy a Clubman.Long live the true Clubman.
- stephenlovesminis
- Whats your location?: Mayo.
To make it easier, and a tidier job, go to your local motorfactors and ask for a "spot weld" drill bit. Have a look along where the wing is joined to the a-panel and inner wing, and you should see what looks like round dimples in the panel, (you can lightly sand it to make it easier to see). thats your spot weld.
Next, drill out these spot welds, taking care not to drill through both panels.
Then, with the aid of a hammer and chissel the panel should pop off relatively easy.
- stephenlovesminis
- stephenlovesminis
Users browsing this forum: No registered users and 28 guests
