Removing rear quarter panel windows?
- Whats your location?: Cork Lad!
- What Minis have you?: 1995 Mini Sprite!
Owned a 1995 Mini Cooper! - Contact:
Any idea where to start with this lads? They are sealed windows! That dont open
- daniel garry
Re: Removing rear quarter panel windows?
peel up the rubber from the inside, the bit that's sitting over the body work. push the glass outwards and work your way around the window
or if you're replacing the seal just cut the old rubbers
Lovely job got that sorted thanks
