Bit of a clear out
just_st3v3n
Bit of a clear out
Post by just_st3v3n »
Right was tidying up the garage and found some excess bits I don't need. Some good some not so good.
998 a series engine,was running before taken out of 74 clubman €125
Loom taken from 74 clubman €25
Selection of stuff.
7.5''grooved discs little surface rust €20
Carburetor (possibly hs4) good for parts as petrol housing is cracked FREE
998 cylinder head with rockers and valves (89 mini a+ engine) €20 needs a head skim (surface rust)
Trumpets FREE
chrome for rear pockets FREE
1/2'' spacers €5
Dash vents (need clean and paint) FREE
4 pot metro calipers (non vented disc ones) need new rubbers and a clean €70
Fiesta calipers (10 inch conversion) + hubs had started conversion but drilled holes 0.5-1mm too big on one hub. Will slide onto your own hubs when holes are drilled out to 10mm easy conversion need good clean and new rubbers €70
Old starter motor FREE
New inner corner scuttle panels €15
Boot lip repair panel €20
Gear selector €20
Also have a set of brand new boxed 8.4 discs €30
Set of 5x10 mambas with good tyres. Need good clean or new lick of paint €175
All parts located in Cavan town, first come first served might be able to get some stuff up to Dublin the weekend.
089 234 0530 , steven
some day....
knock.mini
Whats your location?: Knocknagoshel, North Kerry
What Minis have you?: 1983 Mini
Re: Bit of a clear out
Post by knock.mini »
Im interested in a few of the bits.. Give me a ring when you can.. 087 05 72909
I can also collect
Mini Mad!
I'll take those groovy disks if still available.
Deanmini77
Whats your location?: Clondalkin,
Dublin 22,
Dublin,
Ireland
Post by Deanmini77 »
still got the inner scuttle panels?
just_st3v3n
Discs gone.
Still have the inner scuttle ones.
some day....
