For Sale....998 Engine c/w Box & lots of other Bits
mgb1978
Post by mgb1978 »
Various Parts for sale.
SOLD ALMOST EVERYTHING.
I will relist what's left shortly.
Re: For Sale....998 Engine c/w Box & lots of other Bits
The item you have labeled as SPi relay box is in fact the Alarm modual. It will be coded to the ECU and they will only work as a set unless somebody has access to Rover programming equipment. If you have the Key fobs they will also be coded to the alarm. The lable on the alarm I think is from a '95 Mini which would be useful information for somebody looking for an ECU.
I'll take the fuel tank if we can arrange some way of getting it, maybe meet at the AGM which should be comming up soon.
mgb1978
Post by mgb1978 »
Thanks Woody. I should have the fuel relay Box here somewhere....photo now changed :oops:
I won't be going to the AGM , but if you know of anyone from the Limerick area heading up we could organise something.
