original floor coating?
- armo
imoc member - Contact:
Im in the middle of striping the interior of my 84 mini all floor pans are completely original and rust free but the blavk coating is cracked and some bits missing so my plan is to remove it all clean it back to bare metal repaint and hopefully find something to replace the original coating it had . The problem is that I have no clue wat they used in the first place somone shed some light please
- armo
Re: original floor coating?
Thank you
- Whats your location?: Sligo
Often Known as Sound deadening Pads !!
- armo
Thanks now I just need to find it local and cheap
Any Good Motor Factors Should Stock it.
- Whats your location?: Kilcommon Co. Tipperary
- What Minis have you?: 1988 Austin Mini
I seriously doubt that
- armo
Phoned one of the local motor factor they have it in 500 by 500mm sheets foe 10 euro per sheet
Or just spray it with a coat of Body Schultz.
http://www.vinnybyrne.com/body-shop/sto ... 11460.html
You can get tubs of it and paint it on from Co ops also.
It's pricey enough aroun €30 a litre I think the last time I checked.
