HS4 SU - urgent
- FlyingFinn
HS4 SU - urgent
Is it possible to get twin HS4 SU carbs working properly on standard 1.3l engine or with some tune up? Im thinking of buying ones so advice is needed asap..
‘we come from the land of the ice and snow’
- FlyingFinn
- FlyingFinn
price 80 euro? *really* depends on condiiton... make sure the pistons fall togehter, evenly and without binding. if they do bind not all is lost. it could be a dodgy needle or badly set up jet. and also check for hard to get bits like the linkage. oh, do make sure that its a pair of *twin* su's, not two regular SU's. there used to be a tag on the float chambers with a number which indicated where they came from. not all twin 1 1/2 SU's came from minis: some came from midgets, lots from MGB's an ive even seen them on old mk1 escorts. have you sourced a manifold for them?
- FlyingFinn
While on fleabay, see if you can get yourself a Carb-balancer,i t's used to set the correct air speed through each carb. It can be done by ear, with the aid of a bit of tube, but the balancer is easier to use and more accurate.
While your at it get a petrol can too, twin carbs can drink the juice if you are a bit heavy on the right foot.
- FlyingFinn
yes, you could put a webber on it, or a pair of splt webbers.. €€€€ but really,.. where are you going with this? you will get better economy and dirveability with a stage 1 kit that includes both manifolds, and exhaust. and at €80 you are half way there. if you are re-creating a "look" then the 1 1/2 are fine.
- FlyingFinn
- FlyingFinn
- Merlin
Users browsing this forum: No registered users and 24 guests
