Pumping up suspension
williamt
Whats your location?: Leitrim
Post by williamt »
Anyone know an easy way to pump up suspension... I.e with something lying around... Ive seen a pump on E bay.. Never did it before but think its probably not worth travelling anywhere to have it done when I can buy a pump.. but Maybe there is an easy way to do it... Easy when you know how... Not so much when you don't.... :?
mgb1978
Re: Pumping up suspension
Post by mgb1978 »
Well, it seems they can be made at home. But getting all the parts could be awkward....
http://www.theminiforum.co.uk/forums/to ... -i-make-1/
williamt
Post by williamt »
Thanks so much... Got a link in that with many ways and pictures to make a pump bleeding and filling system... Its on Austin America and click on technical and then suspension..
Anyone here used antifreeze and distilled water to top up system
I thought about making some, but bought a can of Carlube Hydrolastic fluid in a motor factors.
Friend of mine made one with an old pedal box and a brake master cyclinder,I'll see if I can get a picture of it.
williamt
Post by williamt »
Thanks appreciate it... I've a notion I'm going to try using an old external fuel pump.... You know the ones that look like a coil on a mini... If I can get fittings for it... Should be a quick way... As seems people say. Pumping with grease gun is time consuming... Might be a handy wee piece of kit if I get made up
Users browsing this forum: No registered users and 27 guests
