Clubman shell rebuild for vtec
- purplehaze
- purplehaze
Re: Clubman shell rebuild for vtec
Spent a lot of money Thursday
New tires
Everything new for the mini
all new headliner an carpets and seals and stuff
Shud be here Tuesday or Wednesday but hopefully will be fully primed and ready for paint by the time they come! Iv been flat out in work and minding the kiddo
slow updates but
getting there
New tires
- purplehaze
Got at it tonight
more spent but it's coming along and taking shape
Before
After
Gonna do the last if the sanding on the front tomoro!!! Shultz the rear seats and under of the car! Then shell will be primed tomoro night! Then wedsnday block sanded and primed again and sanded then 3rd coat of primer then
put it together and take it apart and paint the bad boy
More updates tomoro evening and hopefully will be fully primed and ready for paint Thursday
woo
Before
After
- purplehaze
Got more done tonight!!! Loads to do tomoro :/ few pics of how it's going
Bit more work to do
first stage of primer now to rub and block it down!!! Then filler and rub and block it down again!!! Then prime it for last time then wet sand it with 2000
then ready for paint
The worst but was this mark on the wing
but that's all
rest of the car is immaculate I'm so happy with how it's looking
door are so straight
all I need is a good bootlid and it'll be complete
Bit more work to do
Progressing nicely
- purplehaze
Getting there matey
tink il hav a chill night tonight and get drunk as I am on holidays
- purplehaze
So good but done last night
ca is 99% ready for paint
just few coats of primer and wet sand with 400/600 sandpaper
body is smooth! No dents no damage
it's all fixed
Wheels send off to get blasted and polished lip
centres are being sprayed hopefully nxt week
New tires came yesturday so when I get wheels back they can be fitted
then I can drive the vtec to garage and rip it apart after the other ones sprayed
could be finished a lot sooner than I thought
so I'm very happy , few pics I got last night
Tires
Till nxt week
hope ur enjoying the updates as much as I am
Tires
Till nxt week
- purplehaze
Re: Clubman shell rebuild for vtec update
New tires going on tomoro
- cianmini1
- Whats your location?: Knocklyon Dublin 16,Ireland
- What Minis have you?: 79 Mini Clubman
- Modifications: Snot-green,bucket seats,straight through exhaust,artificial grass.
I'd say you can't sleep thinking bou it haha
If In Doubt,Flat Out!!!
- purplehaze
So my bro went to garage yesturday and got the car fully primed up! Jus gotta be wet sanded and she's 100% ready for paint
few pictures I got on way to work
As u can see , a rediculous amount of time and effort has gone into the body work
as we have everything else there for it so! Hopefully will be fully painted and dry for Monday so we can put it together! Then send few bits an pieces off to get modified! Then get it running
getting there
Also went and got these done today
Wen I got em
Cleaned em and got polished lip
Tires fitted
ready for burnouts
more updates nxt week
hopefully painted sand getting it together
Wen I got em
Tires fitted
Comming along nicely. Don't know what your interior plans are but normaly you would paint the inside of A and B posts ,crossmember and rear bins the same as outside.
- purplehaze
Yep the bins are black a + b post are going Colour
hopefully paint Monday evening then partially assemble Tuesday
- What Minis have you?: Clubman Estate
Faur play mate some amount of work done on this if i can get mine done in 4 times the amount of time ill be doing well its really coming together it will be sweet when its done
- purplehaze
What are u doing wit yours peter? Hopefully wen it's painted and put together it'll look good
I'm sure itll look fantastic once painted considering the standard of work so far, I plan on repairing all rust rebuild engine or swap for a 1275 if i find a good one and then a full respray and a decent interior if i can find van panels ill replace the side windows with those too
Coming along very nicely ! There will be VTEC minis all over the place soon!
- purplehaze
Haha imagine! Reliable minis everywere
wud be a strange but perfect world! Iv got updates but I'm not posting any more pictures
gonna keep it till mtm you'll all see it then
- purplehaze
Loads done over the past few days!!! Car is painted! Roof lining in new windows fitted and taken bk out to trim roof liner
looks good but no pics!!! Ripped loom from blue one and in the other
so loads of bits an bobs ready to go in!!! Engine is all apart and nearly ready to go in
hers few pics
Only tower bolts holding in! Everything else is disconnected
Interior gutted! Seats out! Got new carpet coz red won't go with wat iv got, steering colum being rebuilt, have pedals in new car already
getting there
Brand new sports pack rack
More updates to follow over nxt few days
- purplehaze
Loads done!!!! Engine out! Brake lines for whole car out and fitted to other one same as fuel lines and full loom gutted trimmed down tidyed up and fitted to clubby
inlet manifold and exhaust manifold off engine and being sent to a mate and modified
new shafts coming in morning so I can take the inners off and rebuild mine make em all new an shiny
gonna clean up everything tomoro and hopefully get engine in the car
here's some pics of progress
Loom + new colum
Fuel sender wireing
Fuel lines
Mani and inlet
That's all for tonight
Loom + new colum
Fuel sender wireing
Fuel lines
Mani and inlet
Also, take the fuel sender wires down through the bottom of the rear bin rather than over it, just my €0.02.
- purplehaze
Nope they run on the outside for a reason so I kept it dat way.
- purplehaze
Just got 3 deliveries today
Number 1 is my two new type r integra shafts
I'm only using the inner cv joints for my honda/mini shafts
Number 2 is my gear shift extender for my buddyclub short shifter
Number 3 is my new arches with self tappers and rubber trim
Also my wheel nuts for my super trax,
Iv got no pics as they in back of car and herself is out
All I'm waiting for is my minispares order, which was placed over a week ago
Lately they're deliveries are taking a longggggghh time
So down garage tonight to rebuild shafts and few niggly bits n pieces
- purplehaze
So got to it again tonight!!! Brought the new shafts down and split them
and stripped the vtec ones out and cleaned em and refitted em
cleaned up everything, fixed one of my lug bolts as one snapped and took the bottom arms off and adjusted a little then cleaned em up ! While I had everything stripped off(hubs,arms,brakes) my bro got cracking on the hi los and suspension cones
all in and looking great
didn't take many pics as was full of grease
but got few
I'm happy with how it's going, inlet and exhaust mani sent off today to get modified
so until I get those back the engine cannot go in :/
Users browsing this forum: Ahrefs [Bot] and 4 guests
