B16a 1968 Wolsely Hornet
Well this is my new project for next year. Some of you will know the plans for it but for those that don't and this wont be one for purist's
This was given to me as a 22 birthday present and i was unsure of what to do with it the wheels started rolling in my head and plans begin to happen for it
Some of the specs and parts that i already have for it
1968 hornet shell
New floors in the front
New sills inner and outer both sides
2 new wings
New front panel
A panels both sides
Doors rebuilt
Boot floor repair
rear arches repaired
Heel board repair both sides
Side window panels under the window both sides
Scuttle repair on drivers side
Inner hinge repair panel both sides
Bonnet repaired
Boot lid repaired and modified
Deseamed bumpers front and rear
Custom bootlid for L.E.D number plate light
Recaro front seats with back seats trimmed to match and door panels the same
Full bolt in roll cage from Rollcentre in the uk
KAD 7.9 vented discs and billet calipers
wilwood master cylinder
Spax shocks
Loads of billet stuff from DSN
(Subframe mounts for the rear
Shock mounts
Door hinges
Bonnet risers
And few other bits)
Fully adjustable bottom arms and tie rods
Camber brackets for the rear
Next was to decide on a engine for it
And only one engine came to mind and that was a Honda B16 conversion
B16a engine
S4c limo gear box
Stainless manifold
Apaxi airfilter
Light weight flywheel
exedy stage 1 clutch
KJB fabrication vtec subframe
Ill try my best to get this updated but for updates as the happen check out minifix on facebook
https://www.facebook.com/pages/Minifix/ ... =bookmarks
Now time for some pictures
Thats all for now
1968 hornet shell
2 new wings
New front panel
A panels both sides
Doors rebuilt
Boot floor repair
Bonnet repaired
Spax shocks
Shock mounts
Door hinges
Bonnet risers
And few other bits)
B16a engine
S4c limo gear box
Stainless manifold
Apaxi airfilter
Thats all for now
- Whats your location?: Louth
- What Minis have you?: '88 Austin Mini
Re: 1968 Wolsely Hornet with a hidden surprise
Really cool. She was in quare shape when you got her.
Looking forward to seeing this finished James, something very different
- joeyfinneran
Re: B16a 1968 Wolsely Hornet
What car are them recaros out of ?
There out a lancer GSR. they are going up for sale as i want bride seats for it instead
- purplehaze
How much was the KJB subframe? Did it come with bottom arms/mounts/shafts???
KJB frame was 650 euro as i got it here but it works out that from KJB themselfs but since he has stopped making them
No bottom arms but they use mini stuff and no shafts with it either but all speed ones will work
My silcone hose kit turned up yesterday and got cracking on working out my pipes for my rad and clearances for everything else around it and fitted my fan to
Also fitted a new dizzy cap and rotor arm to
http://s181.photobucket.com/user/djclub ... g.html?o=1
http://s181.photobucket.com/user/djclub ... g.html?o=0
Well abit of a update
Minisport order arrived
New top arms both sides
New hubs with new bearing and ball joints both sides
competion bottom shock mounts
Brand new back plates with mintex shoes fully built up
Brand new alloy super fins
Brand new 7.9 inch grooved and vented discs
Mini spares order
brand new back subframe
top arm pins
few odds and ends like washers and screws
KAD brakes all built up with new CVs just getting ready to be fitted
Drivers side built up with Delta mini from japan springs and lowered Spax shocks and new track rod ends
Passenger side built up aswell
My DSN billet shock top mounts in blue
THen i hit a little problem my back subframe was welded out of alignment so has to be sent back on monday to get it sorted
Thats all for the min but i will update it when it comes back and has some wheels on it hopefully by the end of next week it should be rolling
Mini spares order
top arm pins
Wow I'd say that order set you back a fair few quid. Top work mate.
it will be basically a new car benny when it is done so what has to be ordered will be ordered. sure it is only money at the end of the day
Dead right, I like your attitude.jocelynn wrote:it will be basically a new car benny when it is done so what has to be ordered will be ordered. sure it is only money at the end of the day
Well a big up date
Heel board all fixed and rear subframe fitted today after it only came back on monday
Rear subframe fitted
radius arms are fitted
new back plates fitted
Superfin drums fitted
rear shocks fitted
Also got my driveshafts from Rob in Allspeed and don't they look great
Wheels fitted to make it roll
Cage mocked up and bride brix seat mocked up and rolled it out side for some pics
Also mocked up my rocket bunny rear wing
Thats all for now
Hope to get a start on the loom next week and get my clocks mounted in the dash i have coming from ABS motorsport
Also waiting on my inlet to come from getting modified and welded
rear shocks fitted
Thats all for now
- CB_Phil
- Modifications: Few bits
spoiler gives her a bit of a Jap look.
you go with Gizmo for the welding of the manifold?
I got AandD Fabrications to do it for me at the back of st margrets
- daniel garry
2 years without an update?! This ever get finished James?
Pretty much on the back burner for the min. as my other 87 city took priority over this but here will hopefully be a update in the summer on it
