Moderators: spud1979 , The Marcos Graveyard , Moderators
seanos
Posts: 360 Joined: Thu Jun 11, 2009 11:55 pm
Post
by seanos » Mon May 12, 2014 1:52 am
I've discovery some rust on the front floor panels and the sills.
If I replaced the floor panels would I need to replace the inner sills too,
http://www.minispares.com/product/classic/MS25R.aspx
or does this panel include the sill?
Has anyone used this panel from mini spares before?
Is it hard to fit?
Here's a few photos of the rust, any recommendations on what to do would be great!
Posts: 990 Joined: Wed Mar 30, 2011 2:42 pm
What Minis have you?: 1980 clubman b16 vtec 1992 mini shell, getting turbo,d 1974 clubman estate
Post
by purplehaze » Mon May 12, 2014 2:00 pm
As far as I know! U just need that panel then the out sill!!! There are still the doorsteps! And if the driver side is like that be sure to check the others side!!! Strip ur interior and check back, sides! An front on both driver and passenger sides!!! Check ur door hinge inanely also an boot floor coz If your floors are like that there cud be hidden treasure everywhere
seanos
Post
by seanos » Tue May 13, 2014 12:39 am
The rest of the body seams fine, the only places that seem to be bad is the sills and around the air vents, I plan on blanking these off.
seanos
Post
by seanos » Thu May 22, 2014 11:57 pm
I've cleaned down the floor pans and out sills.
When I'm replacing these panels which one should i do first?
And do I need to brace the door, remove subframes?
seanos
Post
by seanos » Tue May 27, 2014 12:41 pm
anyone?
