Running wrong
Re: Running wrong
Problem solved. Was the live wire going to the ecu was damaged and was hitting off the body. But with all minis it's never that easy. On the way home the clutch went. Ffs patients running thin
coolmini
Mayo
Re: Running wrong
Post by coolmini »
Well at least that's one problem solved. Clutch ain't that expensive.
As in one usually just needs the clutch plate.
Re: Running wrong
If you get a clutch kit make sure the pressure plate is identical as there are some for non injected engines that will upset the timming.
Re: Running wrong
Wasn't my clutch after thank god. The fluid had gone low on my slave cylinder and couldn't get it into gear. Sorted now and flying again for another day. Well as a mini owner you can't say you dont learn new stuff everyday about your car
Dilogoat's Gruff
Re: Running wrong
Post by Dilogoat's Gruff »
Haha, typical mini issues! What's next? I think it's problems like this that make mini ownership so expensive. Something goes wrong and I just replace the whole unit, easy! Then I realise it wasn't that all along and something else needs replacing. Joy!
Re: Running wrong
The joys of minis is right. Money pits but good fun too
Re: Running wrong
If the fluid was low it must have a leak,pull back the dust cover on the slave cyclinder and see is it wet
Re: Running wrong
No we are flying it again thanks Bert. Prob not right to have one as a daily drive and driving nearly 150 kms each day
