Dim dip lighting system on spi
speedy
Whats your location?: Lucan, dublin
What Minis have you?: 1992 brg mini Cooper spi
Post by speedy »
Hi folks,
Hope somebody can help me out...
Basically my new battery has been drained,
I traced it back to the dim/dip relay(pink relay behind dash).
The drain stops when I remove the relay or the fuse that powers it!
Is this relay of any use, everything still works when it's removed,
well I think it does!
Will I remove the relax, take out the fuse? Or do i need to short anything at the relay??
Save me from trying to order one in!
Cheers
mgb1978
Re: Dim dip lighting system on spi
Post by mgb1978 »
You don't need this feature. It was an attempt by BL to bring in a feature ahead of a regulation that never happened.
Either remove the relay, or just cut the Green wire (and tape up the remaining feed end) that feeds it. If it were me I would cut the wire , this will isolate the relay completely.
Users browsing this forum: No registered users and 26 guests
