1984 mini mayfair project
jcrothers
What Minis have you?: 1984 mayfair
Modifications: paint two tone colour
Post by jcrothers »
Hi my name is Jonathan here are photos of my project up to date. I will add more photos from the start of my project at a later time.
[img]http://i1352.photobucket.com/album ... .jpg[/img]
Re: 1984 mini mayfair project
Very nice Jonathan, liking the two tone paint.
Welcome to the forum.
jcrothers
Post by jcrothers »
Thank you
I bought the car painted like that as a shell ill add more photos
jcrothers
Post by jcrothers »
The photos below is the way I bought the car as a painted shell with the parts in boxes.
(Tags sorted, no nee to add URL tags to the IMG Code tag from photobucket.................TMG)
Colour scheme is cool 8)
You'd wonder why someone would do such a nice job on the paintwork but not bother to do the small bit of welding need first :shock:
jcrothers
Post by jcrothers »
jcrothers
Post by jcrothers »
maverick
Whats your location?: Belfast
Post by maverick »
That's a lovely mini you have there. Nice original touches too. Hope to see it in the tin this year!
jcrothers
Post by jcrothers »
Thank you
I hope to have it on the road in the next month or two
Lovely looking Mini you got there,the colour scheme is really nice.There is a Mini in the current Mini Magazine with a gold and brown scheme like yours and it looks class as well.Hope to see it out and about on runs soon.
jcrothers
Post by jcrothers »
Thank you. Cool ill get it and have a look. Ya I can't wait to get it on the road.
JayJay
Whats your location?: Dublin City
What Minis have you?: 1998 Mini Cooper - Sold :(
Post by JayJay »
Nice work on the two tone. Its not something Ive seen before but I likes it.
Great step by step photos too
jcrothers
Post by jcrothers »
Thank u. I'll have more photos up soon.
jcrothers
Post by jcrothers »
Hi all haven't had a chance to do much in the last few weeks because of the new job.
Got the Mini started yesterday for the first time.
Test fitted the wheels and aches to see what they looked liked. Need to get the proper nuts not sure which ones any advice would be great? and I need to get better centre caps any ideas would be great?
(Post tidied up by MOD.......... unfortunately the forum is not configured to play/host any video format at present)
For the nuts you will need to contact the manufacturer to see what the angle of the chamfer is required on the seat of the nut, usually 45 degree or 60 degree.
What size wheel centre do you need I have a few chrome ones that might suit.
jcrothers
Post by jcrothers »
sorry only getting back to u now I got sorted with wheel nuts and I have centre got centre caps too.
Here's a small update
I had to change the water pump so I did a bit of painting
[URL=http://s1352.photobucket.com/user/ ... .jpg[/img][/url]
need to clean the engine bay some more
I also put the new wheels on
CB_Phil
Whats your location?: Dublin,
Modifications: Few bits
Post by CB_Phil »
As said, love the paint, seen similar in a mag & have been cursing it since as I said I wouldnt touch the paint on mine! but looks 8)
shes coming along well too man look forward to seeing her all done
jcrothers
Post by jcrothers »
Thanks Phil
here's some photos from the weekend
I had to cut slots in the bumper where the hinges are because the bumper wouldn't fit on and I desided to paint them black
Then I edged primed it
I also checked the breaks the front are fine the back are bad ill have to rebuild them Im not sure if I should just do the hole sub frame it has a bit of rust on it.
front breaks
jcrothers
Post by jcrothers »
My rear sub frame and rear breaks where looking like this
So I did a rebuild of the breaks and sub frame
[urlImage][/url]
I used a angle grinder with twist wire bushes to take the rust off
paint on rust remedy to treat the rust
Than I painted acid etch and a chassis/stone chip paint on it
The car looked like this for the day
more photos to follow
Nice clean up job on the rear subbie and I like the on street garage although you don't have the optional gully for fluid disposal like Macker had. :D
jcrothers
Post by jcrothers »
thank you Kerry.
more photos. i got the back plates sand blasted,I rust treated them and than painted them with high temperature paint.
I also stone chipped under the back of the car and arches. The shocks are just rusty they work fine ill change them some other time.
Brakeshoes on backwards :shock:
jcrothers
Post by jcrothers »
O no thank you. what way should they be on? I was looking at the haynes manual tho i had them right :(
The way I remember is that when the wheel is rotating in a forward motion the drum should pass over the bit of the shoe that does not have friction material on it if that makes sense. :shock:
