1983 Mini Project!
knock.mini
Whats your location?: Knocknagoshel, North Kerry
What Minis have you?: 1983 Mini
Re: Project:1983 leyland mini
Post by knock.mini »
thanks lad.. il keep the updates coming
Mini Mad!
scotty_1987
Post by scotty_1987 »
coolio look forward to em :lol:
cianmini1
Whats your location?: Knocklyon Dublin 16,Ireland
What Minis have you?: 79 Mini Clubman
Modifications: Snot-green,bucket seats,straight through exhaust,artificial grass.
Post by cianmini1 »
shes looking well man keep it going!!
If In Doubt,Flat Out!!!
knock.mini
Didnt update in a while now.. buying a welder soon so full steam ahead
Mini Mad!
knock.mini
Been super busy with a hot rod car and school so not much has happend!.. Have a week off school now so keep an eye out!
Mini Mad!
knock.mini
So i got a question for everyone.. I have a 998cc mini engine out of a donor car same year and model as mine.. looks fairly rough but would it be worth it to rebuild it maybe just like a goodclean out and stripped and new gaskets and maybe new head?..
I honestly dont have much clew whats wrong with it because i used thecar for spare subframe and interior parts..
Any considerations are appreciated highly,
Kieran.
Mini Mad!
strip it down anyway, If it's terminal you'll find out and if it's workable rebuild it with new parts where it needs and it should be good again :D
knock.mini
would it be worth it? moneywise like?.. when it breaks im planning on going vtec :twisted:
Mini Mad!
knock.mini
Well i ripped out that engine and its not looking good, when i took out water pump there was gunk everywhere and when i took off the head there was brown pooey kinda gunk.. shes seized aswell so she isnt worth saving, is she??
Mini Mad!
knock.mini
Will have updates soon.. panels off and welding in at the moment.. buying a 1275 engine off a mate and ordering disc brakes soon.. have been busy with work
Mini Mad!
knock.mini
Welding is getting there.. have no time with school and work.. ill try put up some photos soon.. pm me if yer looking for parts also.
Mini Mad!
knock.mini
Mini Mad!
knock.mini
knock.mini wrote:Image
So as the welding underneath was done i went on to clean everything down to bare metal. Etch prime the lot, then wax oil, a coat of stone chip and finally some grey zinc primer.. Which is close enough for the colour im going for so i said that would do!
So the welding on the outisde was also finished.. new wings, front panel, A panels.. so i cleaned everything down to bare metal and acid etch primed the lot.. This gave me a nice clean surface for me to paint on in the future..
So lately i out the subframes back on.. with adjustable GAZ shocks, hi lo suspension and adjustable arms ..
At this point i was getting excited and now that it was rolling i could actually see it looking like a car again :lol:
I also primed the engine bay and the inside of the car! to cut costs on the respray ill be painting the engine bay and inside the cab myself!
[imgImage][/img]
[imgImage][/img]
Thanks for giving a look! Im currenty rebuilding a 1275 engine also.. dont have photos yet but the plan is to freshin it up with new camshaft.. new bearings.. new clutch..skim the head and other bits to keep it going a while!
Also if anyone has an electronic distributor for sale or a webber carb.. Let me know! :shock: :D
Thanks a mill for viewing!
Re: 1983 Mini Project!
Good to see another project coming together. Keep us updated.
knock.mini
Thanks Billy much appreciated! It was on hold for a while now but back in action now.. By any chance you know much about removing the flywheel on the engine.. Im using the puller tool and everything but she wont budge.. Would applying a small bit f heat to the shaft be a bad thing to do..?
Mini Mad!
Any advice out there, guys?
Mini is comming along nicely .
On the flywheel , have you definitly removed the locking washer at the end of the crank, when you look in you should see a slot accross the crank and flywheel.
Measure the tops of the 3 bolts on the puller to the face of the flywheel and make sure they are the same lenght to insure that the puller is pulling straight.
Tighten the center bolt on the puller as much as you can and than strike it sharply with a heavy hammer. The shock can release the flywheel with a bang and mind your feet.
If all this fails than you can heat the flywheel and again shock it.
I only ever had to heat one up and that was on a botched up turbo with A+ primary gear and A gearbox and drops.
Good luck
knock.mini
Thanks very much Woody! Yeah the key way what i call it is it? Ill try that so.
Mini Mad!
Users browsing this forum: Google [Bot] and 20 guests
