Distributor help/advice needed
flynny-8
Whats your location?: Co.cork
Post by flynny-8 »
Well I haven't posted here in a while but thanks to Colin and Joe whyte my mini now has a working 998 engine so im over the moon now, however there's an issue with the distributor whereby oil is coming back up and out. Joe took the distributor apart and it all looked fine on the inside but theres a fair amount of oil being left behind. Im wondering if anybody can tell me why and if its a simple fix and if not where I could pick one up handy anywhere around munster.
Its an electric distributor and the numbers on it read ;
AUU1082 2001
42626J 0388
Cheers, Darragh
Re: Distributor help/advice needed
Is the O ring intact on the shaft of the distributor,is oil coming out anywhere else like the dip stick?
minivillian
Post by minivillian »
kerryminigringo wrote:Is the O ring intact on the shaft of the distributor,is oil coming out anywhere else like the dip stick?
O ring is perfect on the shaft of the distributor and no oil appearing anywhere else.
The oil isn't coming out around the distributor shaft but rather going up through it and coming out of the body of the distributor and around the vacuum advance.
Sounds as it colin has come across the answer on the web, the oil pressure release valve may be stuck, causing the oil to back pressure through the dizzy, the marcosgraveyarddoesnothingwithamini :D told me before they stick and to replace with the ball from a cv joint
flynny-8
Post by flynny-8 »
Well joe, I took out the spring assembly and sanded down the metal cup which was fairly cut to bits but no luck on stopping that leak unfortunately. I might take it out again and have another look over the weekend.
