Need help!!! Something wrong
My bro got the car back together
But has this problem, passenger side is fine
But driver side is sittin way forward and hitting the arch wen on
Passenger side
Driver
Anyone know what's going on here!?????
Cheers
Re: Need help!!! Something wrong
Warped subby ?
Was it in a crash ?
armo
Whats your location?: dublin
imoc member
Post by armo »
Never crashed . Only noticed when I fit different arches ... Looks like its all coming out agen gonna lose the plot with the car I tink it's been like that a while but not sure
Finish mine den worry bout yours :)
Backfire
Whats your location?: Lucan, Dublin
What Minis have you?: 1979 VTEC Mini clubman
Post by Backfire »
Is it a fibreglass front? There are a good few reports on line of guys being sold warped fibreglass fronts that don't fit the best straight from the box.
No it's all original never crashed r damaged in any way
THOMAS
Post by THOMAS »
Is there a spacer missing between front of subframe and body.
Think when 12 inch wheels are fitted there is a spacer fitted to push body forward a little piece.
armo
imoc member
Post by armo »
No the back of the wheel on driver side has a bigger gap as aposed to pasanger side and smaller gap at the front
Did you send the subby off to be galvinised ?
armo
imoc member
Post by armo »
Nope it hasn't been off the car
Have you changed the subframe bushes? The tierod bushes at the front will move the wheel foward or back. Make sure the RH front teardrop hasn't been replaced by a towing eye or large bolt.
armo
imoc member
Post by armo »
I changed the driver side floor mount and driver side tie bar bushes to see if it would help but no difference was really east to change the floor mount it lined up near perfect first go . Tie bars are strait I'm baffled and I'm nearly sure it's always been like that
molly the mini
Post by molly the mini »
Would the tie bar be bent its easy done with a jack
armo
imoc member
Post by armo »
Tie bars are strait
Is their a rubber missing at the front of the tie bar?
has the tie bar been tightened too much?
what are the castor angles like?
armo
imoc member
Post by armo »
It's looking like the front subframe bush has shat itself changing it now and crossing my fingers
armo
imoc member
Post by armo »
Well that made no difference I'm lost
armo
imoc member
Post by armo »
The car is sitting low on the drivers side by about half an inch
knuckle joint may have dropped, if it has it will need to be replaced,
If it has it will mean that when the joint is replaced the car will sit more level and judging by the gaps at the moment it may well bring the drivers side wheel gap to the same as the passenger side wheel,
did this car originally have 10 inch wheels on it?
armo
imoc member
Post by armo »
Always had 12s. I replaced the tie bar bushes tear drop and floor mount on the driver side to try sort it but no joy the ball joints are fairly new everything looks strait and replacing the floor mount was fairly easy I just wana bang my head off the wall
Remove the two front wheels then with both doors closed measure distance from back of doors (lock side) to where the front seam hits the arch and to where the front panel and wings meet the arch. Compare measurments on each side. May have a slight tip on the right.
armo
imoc member
Post by armo »
Ill give it a go ... Heading down to the car now so ill no in an hour
mgb1978
Post by mgb1978 »
you can also try measuring front to back hub centres on both sides.
If the driver's side measurement is slightly longer then it starts to look like a tie-bar issue....if not, then it's either crash damage (or cheap aftermarket front panels, possibly the real culprit).
armo
imoc member
Post by armo »
Thanks for all the comments so far
The wings front pannel ect are original
The car is sitting low could the problem be a cone??
My plan is to drop the subframe replace all bushings and if nesissery
Replace cones
So far I have replaced
Tie bar bushings
Bottom arm bushings
Tear drop
Subframe floor mount
All on the driver side and its still low
Losing my mind at this stage . I forgot to bring a tape to measure but ill
Do that tomoro I'm giving up for today
Knuckle joint as said above :wink:
