Hi guys going to fit my windscreen soon as the final jobs get done. any tips? type of sealent etc.
Fitting a windscreen
- mini_sprite94
- Whats your location?: just out side Mitchlestown.
- What Minis have you?: 1995 Mini Sprite, Elmo.
- Whats your location?: Belfast, Northern Ireland
- Region: Northern
- What Minis have you?: 1966 Mk2 Works Replica
1967 Mk2 Cooper (Penelope)
1959 Austin Seven Barn Find - Location: Belfast, Northern Ireland
Re: Fitting a windscreen
Some speaker wire (split the two cables and use one)
Don't use fairy liquid, WD-40 is made from fish oil and won't damage the seal, vaseline is also good, but has been known to cause issues down the line.
Before you start, make sure the seal fits. There have been quite a few batches of seals recently that were too big for the window they were meant to fit.
For the filler strip, I have found a watchmakers screw driver with masking tape over the tip works well.
Sealant wise, anything I have done has never needed a sealer, but Tiger Seal is my weapon of choice for weather proofing grommets and engine bay holes. It can also be tidied up quite nicely by licking your finger and running over it in a smooth action if required.
00(44)2890 301430 | www.brooklandsmg.co.uk | MG & Mini Parts Specialists
