Brake bleeding
- Whats your location?: cork
- What Minis have you?: 1975 saloon MG Metro powered
- Modifications: MG Metro Goodness
Brake bleeding
Hi all,
i have changed from drums to disc/drum on my 75 car i went to bleed them and done them
in the right order but the pedal is soft and goes to the floor when i pump it ,it gets hard
and then soft
any ideas it the early type set up with a single master cylinder
cherrs
and then soft
cherrs
Re: Brake bleeding
I had the same problem on mine when I changed it from drums. I made the common mistake of putting the callipers on the wrong side of the car. Switched them around and all was good.
Re: Brake bleeding
What type of master cylinder do u have
Re: Brake bleeding
I just refurbed the original one that was in my car. Works no problem.
Re: Brake bleeding
Thanks but was it an early type single lockeed one
- Whats your location?: Athlone
Re: Brake bleeding
I had the same problem bleeding brakes, I tried and my local garage tried but we couldn't bleed them....... Then the guy at the garage looked at the calipers and wondered why the bleed nipple was at the bottom of the caliper !!!! Yes, they were on the wrong side...... For two months !!!! Check that the calipers are on the right side ie bleed nipple facing up
Re: Brake bleeding
Here's a picture of my engine bay just after i put the engine in. Hope it helps.
Re: Brake bleeding
Thanks what year is your car?
Re: Brake bleeding
It's an '81.
Re: Brake bleeding
Thanks steve can i ask on the rear subframe do u have a T piece or a brake limiting valve?
Re: Brake bleeding
As far as I remember its a T piece Dave.
- joebe1
Re: Brake bleeding
Did u put new calipers on or rebuild old ones? Check that u put the copper washer on the brake hose on the caliper. If all is good at that point, use hose clamps to clamp one of the brake hoses on one of the calipers, put ur foot on the pedal if no change, change clamp to other front hose. Ur isolating each caliper and therefore determining if one has an issue as theres air getting in or fluid coming out somewhere. hope this helps
Re: Brake bleeding
Thanks for that what would this prove by doing that
Re: Brake bleeding
Get an Ezi-Bleed kit, uses pressurized air to push the fluid through the system, one man job.
