NCT
clubmankev
NCT
Post by clubmankev »
Hi all, had the nct today and came away with a failure on a suspension imbalance.
According to their 'equipment', the front axle showed an imbalance of 41%, with 30% being the limit, while the rear crept in at 29%, just acceptable. The strange thing is, if you rewind 2 years and 3000 miles, the readings were 9% and 2% respectively and if you look at the 2008 report (5000 miles ago) the readings are 3% and 7%.
Could it be that the rubber has deteriorated dramatically in the last couple of years, or could something else explain the dramatic increase?
I intend replacing the cones all round before the retest to be certain. It was on the list of jobs anyway, just it'll be done sooner than planned.
Any input or theories appreciated.
MINI
...where size doesn't matter!
DOUGAL
Re: NCT
Post by DOUGAL »
I had the same problem with suspension imbalance on a Mini last year .
I done a few jobs on this Mini for a guy that worked in a D O E center .
He checked the imbalance on eheir tester ( which is the same as N C T one )
and readings well within tolerence . But N C T readings through the roof ??????
took it back to N C T ( done nothing to car ) and it passed .
The Mini ( being so narrow ) is hard to get on the tester just right .
Get it tested somewhere before u doo enything at least then u know if u have a problem .
DOUGAL
Re: NCT
Also check that your tyre pressures are correct all round
Re: NCT
Hi-Lo not set up right can put extra weight on the higher corners.
clubmankev
Re: NCT
Thanks for the replies folks, Tyre pressures were spot on and she is still sitting on the original fixed suspension, so no worries with adjustable bits. I'm still convinced it was down to the equipment or the way it was put onto the plates.
MINI
Re: NCT
Was it Fonthill?
clubmankev
Re: NCT
Yes Dave, the very same.
MINI
pn951
Whats your location?: Cork
1979 Pick-Up
1990 RSP Cooper
1991 Lamm Convertible
1992 Mayfair
Re: NCT
Post by pn951 »
On a normal car suspension imbalance is usually sorted by changing the shock absorbers as thats what they are really testing. Not sure on the Mini rubber cone setup though. As suggested, get a 2nd reading done.
mgb1978
Re: NCT
Post by mgb1978 »
As pn suggested above it is the shocks themselves that have the imbalance. They have to be replaced in pairs to eliminate the imbalance.
It's measured as much in the rebound as the compression, so the Rubber cones themselves won't really affect the readings.
In fairness the front shocks are probably the cheapest major suspension parts to purchase.
The funny thing is if both shocks were totally knackered the car would pass, as there would be very little imbalance :roll:
Re: NCT
mgb1978 wrote:As pn suggested above it is the shocks themselves that have the imbalance. They have to be replaced in pairs to eliminate the imbalance.
there's your answer right there!
take out the two front dampers and drive it in on the donuts :lol:
clubmankev
Re: NCT
Thanks for all the useful feedback guys.
Ill get a fresh set of shockers for her and we should be laughing.
MINI
