Moderators: spud1979 , The Marcos Graveyard , Moderators
Posts: 4649 Joined: Mon May 09, 2005 12:49 pm
Post
by Billy » Wed Aug 01, 2012 11:07 pm
Post
by Billy » Sun Aug 12, 2012 7:58 pm
Haven't been near it in over a week so decided to remove the side windows and interior panels today.
The wheelwell hole is getting bigger all the time.
Next will be the rest of the interior.
Posts: 2822 Joined: Mon Feb 07, 2005 11:55 pm
What Minis have you?: Traveller Turbo Hornet Equinox MINI Clubman
Post
by woody » Sun Aug 12, 2012 9:38 pm
You'll be able to get a 13" in that wheelwell soon
Post
by Billy » Mon Aug 13, 2012 9:24 am
It's looking that way and I'm afraid to think what it's going to look like after blasting.
madjackjr
Posts: 477 Joined: Tue Jun 19, 2007 5:06 pm
Post
by madjackjr » Tue Aug 14, 2012 8:30 pm
[quote="Billy"]It's looking that way and I'm afraid to think what it's going to look like after blasting.[/quote]
Swiss........... as in cheese. Good bit of work on this one, but hope its not that bad after blasting.
FlyingFinn
Posts: 50 Joined: Tue Apr 03, 2007 12:10 pm
Post
by FlyingFinn » Thu Oct 25, 2012 10:32 pm
Hey Billy, I've also spotted a 60's van in need of some major rebuilding. Have to get back to you if I get it.
‘we come from the land of the ice and snow’
Posts: 876 Joined: Wed Feb 03, 2010 1:13 am
Post
by joeyfinneran » Thu Oct 25, 2012 11:37 pm
Dont give it to him he'll cut it up
Post
by Billy » Fri Oct 26, 2012 9:43 am
FlyingFinn wrote: Hey Billy, I've also spotted a 60's van in need of some major rebuilding. Have to get back to you if I get it.
Tommi, you could then bring the greyhounds to Mini events!
FlyingFinn
Post
by FlyingFinn » Fri Oct 26, 2012 1:52 pm
Here is a picture of what I got:
Just have to organize the pick up and get working.
(Img tag sorted......TMG)
Post
by woody » Fri Oct 26, 2012 7:03 pm
Are thoes number plate brackets above the bumber?
Post
by joeyfinneran » Fri Oct 26, 2012 7:17 pm
Could be spot light bracket
Post
by Billy » Fri Oct 26, 2012 8:23 pm
Some recent updates. The biggest problem with my shell is the crater where the wheelwell used to be. Thankfully another man handy with an angle grinder, kerryminigringo, was cutting up an estate shell with a much better rear so off ZAKGT and I set off to collect it.
And to get it home, I tied it onto the trusty Volvo for the trip back to Co. Cork
The plan was to get it to a sodablaster in either Limerick or Cork but I've just found out there's a guy after setting up just 4 miles away from me. So once the next Mini for the chop (a 2000 Cooper) is off my trailer on Sunday, I can finally get the Clubby off to be blasted.
Posts: 1532 Joined: Sun Feb 06, 2005 10:52 pm
Post
by DaveC » Fri Oct 26, 2012 9:36 pm
Plenty to keep you busy there Billy
FlyingFinn
Post
by FlyingFinn » Sat Oct 27, 2012 8:05 am
Sorry to spam here, but what kind of a transmision is this?
I've only seen Billy's 60's automatic.
some more pics:
Post
by Billy » Sat Oct 27, 2012 9:07 am
Tommi,
What you've got there looks more like an estate with the cover for the spare wheel in the back.
The gearstick you have is very early and is known as "the magic wand". It's definitely not an automatic and is probably from the easily '60s.
First frost here last night. Probably a lot colder in Finland.
mmurfee
Posts: 480 Joined: Wed Apr 30, 2008 7:29 pm
Post
by mmurfee » Sat Oct 27, 2012 1:13 pm
Billy that clubman read end has done a bit of travelling, if its the same one i had here.
Post
by Billy » Sun Oct 28, 2012 8:51 am
It is indeed, Martin.
Post
by Billy » Sun Oct 28, 2012 2:53 pm
The discovery of 19-year-old petrol has shone a new light on the integrity of the tank.
With the headlining, tank, pedals, wiring loom, and handbrake removed yesterday, the shell is finally ready for blasting. Fingers crossed it should go to the blaster tomorrow for collection later this week.
FlyingFinn
Post
by FlyingFinn » Sun Oct 28, 2012 4:46 pm
Is the empty shell easy to manhandle?
Posts: 4720 Joined: Fri Feb 04, 2005 10:05 am
What Minis have you?: 1971 Mini Marcos. 1984 Mini Sprite
Modifications: 1380cc Weber45 S/C CR gearbox and drop gears
Post
by The Marcos Graveyard » Sun Oct 28, 2012 7:08 pm
You won't find the holes in the tank till you remove the rust.
Been there, done that, got the paperweight.
Posts: 2680 Joined: Thu Feb 10, 2005 9:44 pm
What Minis have you?: 61 van,68 MKII, 75 Clubman estate, 80 1275GT 91 RSP Cooper
Post
by kerryminigringo » Sun Oct 28, 2012 8:51 pm
You have an odd van there Tommi,it has an estate floor where the spare wheel is stored under the floor at the rear.Most vans had the spare wheel stored under the load bed behind the passenger seat.It looks like one piece windows where put in the back along with a rear seat conversion.It also have the cold climate heat in the engine bay.Check the wiper motor for a date and this will give you an idea of the age of it.
Post
by Billy » Sun Oct 28, 2012 9:09 pm
The Clubby is ready to go, there's nothing left to strip off it. It will be on the trailer tomorrow morning and off to the blaster, 4 miles away.
With the Clubby estate ready for blasting, it was time to sort out the replacement rear floor sourced from KMG
The green stuff is fungus and moss.
The two panels either side of the wheelwheel are just pop rivetted and fairly easy to take off.
Post
by The Marcos Graveyard » Mon Oct 29, 2012 11:08 am
You're getting the KMG floor blasted too I hope.
Post
by woody » Mon Oct 29, 2012 11:26 am
If your only using the wheelwell save as much of the rear floor as you can as its no longer available.I had to make one for my woody.
Tommi's van sure is unusual, any idea what country it was assembled in?
Post
by Billy » Mon Oct 29, 2012 5:22 pm
Clubby safely delivered to blaster. Will have it back later this week.
