Must have tools
- joeyfinneran
Must have tools
As i will be getting into my project wit the exams over and it has no engine and will be referbing the suspension and fitting the engine and getting it running (bodywork is perfect only one rust spot on the hole car)
What tolls will i need to get for a mini restoration ?
Tools i have :
Ball joint splitter
Torque wrench
Big socket set just got it for the tower bolt socket
Also have a smaller socket set
Have the cone conpression tool
And windscreen sprip tool thing
Have a chain pulley in other shed but not sure on max weight but porbably would lift a engine
Vise
Bench grinder
Angle grinder
Grease gun
Ps (no point in creating another thread)
Even tho theres not much welding to be done i dont plan on doing it myself but im sure i will on furture project do ye recommend spending 250+ on a welding course of should i but on and learn by practice?
Tools i have :
Ball joint splitter
Torque wrench
Vise
Bench grinder
Angle grinder
Grease gun
Re: Must have tools
The 2 large sockets needed for the Mini used to be 1"1/2 and 1"5/16 however some of the newer CV joint kits come with a metric size nut that requires a 38mm socket.
A proper punch for drifting out the roll pin in the gear linkage is an invaluable tool, it has a small pip on the end to help locate the drift on the pin which stops mushrooming the head of the pin.
An Ezi-bleed kit for bleeding the clutch or the brakes when you're on your own in the garage at 1:45 in the morning.
A good set of 6 walled imperial combination spanners.
A breaker bar or a length of scaffolding pipe to fit over a socket set's sliding T-piece to give you extra leverage for undoing stubborn hub nuts/flywheel bolts.
A basin or similar and some small paint brushes and paper towel for cleaning parts.
Re: Must have tools
I'd add a big box of disposable gloves, barrier cream, eye protection, WD40 and gunk de-greaser.
- joeyfinneran
Re: Must have tools
Diposable gloves
afraid to get ur hands dirty ? Jeysus i hate wearing gloves
- DaveC
Re: Must have tools
A jack and axle stands
Lump hammer
Lump hammer
- joeyfinneran
Re: Must have tools
Have them allDaveC wrote:A jack and axle stands
Lump hammer
- Whats your location?: Athlone
Re: Must have tools
Deep pockets !!
Re: Must have tools
Set of ring spanners and cut a hole down through one for the brake pipes if your doing those too.
That and a long nose vicegrip make taking them off so handy as I found they can be a nightmare to get off if you round them!
Re: Must have tools
You can get proper break pipe spanners as well as a spanner for the break adjusters on the rear of the Mini.
- daniel garry
Re: Must have tools
these.....http://www.craftsman.com/craftsman-8-pc ... ckType=L10
nom nom nom!! pity they dont deliver to ireland
Re: Must have tools
They do through Sears.com but the delivery is frightening
- daniel garry
Re: Must have tools
i found sears last night and i think thats the 1 set of spanners that isnt available for international shipping!!Billy wrote:They do through Sears.com but the delivery is frightening
like you said, crazy shipping costs though
Re: Must have tools
some pliers, snips, junior hacksaw (+ extra blades as they snap like twigs when you need them) and a large adjustable grips
Re: Must have tools
a good book of swear words, you'll find an time when you will use most of them
- joeyfinneran
Re: Must have tools
Used plenty if them last night changing my engine steady
