Help with surface rust.
- stephenlovesminis
hi all can someone help me with surface rust my mini is starting to get it now after i sanded to get it ready for paint but the person painting it cant do it until the summer can someone tell me a good way of keeping the rust away? or is there away?
please HELP!!!
im getting worried!!!!!!!!
please HELP!!!
- stephenlovesminis
I'm no expert on painting, but any bare metal on your Mini will rust in no time.
I would suggest that you remove the surface rust by whatever is your preferred method, wire brush/sanding disc/rhino pad , wipe the panel clean with a tack rag and apply a coat of primer or etch primer and let it dry.
When it comes to repairing/replacing any panels then it is just a case of removing the primer from the area of the weld.
- stephenlovesminis
- stephenlovesminis
- stephenlovesminis
