Headlight
Headlight
Today i noticed that my passenger headlight is not working
Dimps and parking lights both work is this just the blub thats wrong ?
Does the blub have two elements or somthing ?
P.S webmaster if you read thanks for puttin "seen a mini" as a sticky :D
GTM Coupe
Re: Headlight
Post by GTM Coupe »
Yes the bulb has two filaments one for dip one for high beam, quite common for the high beam to go, there are 2 types of bulb fitted to minis, one is a complete sealed unit (i.e. the whole glass unit) or and H4 bulb.
Re: Headlight
Oh good thank god thats not too bad
The little bulb under the main bulb dont work eather would that be the same ? Just te bulb gone?
GTM Coupe
Re: Headlight
Post by GTM Coupe »
yes
Re: Headlight
Thanks for the help :D
Everyone on this forum is so nice in comparson to "theminiforum" :)
Re: Headlight
I had the same problem a few weeks ago but it turned out to be a loose connection in the loom where the LH lights are connected to the RH ones. The connector is located running under the bonnet shut panel.
