spot light positions
- Darren
- Whats your location?: Castledaly.......
between Athlone & Moate
Co. Westmeath
Region Midlands - Region: Eastern
- What Minis have you?: 1988 Black; MaryQuant Designer
- Modifications: Just a fresh new face, no engine mods yet !!!!!! Loads still to do.
Hi, I'm Sticking 2 pair of spots on the car, whats the best distance from the original holes to drill for the extra pair ? Thanks !
Cheers
Darren
Darren
- Whats your location?: Mayo.
Re: spot light positions
The best spaceing for 4 spots would probably be as they were from the factory.
I'll take measurements off a factory cooper and give you a shout tomorrow evening, unless someone else can sort you before that.
- Whats your location?: wicklow
- What Minis have you?: 1275 mayfair auto.
- Modifications: stage 1 kit
hi i just measured mine from the factory holes, from the centre of the bonnet drop to the centre and then the holes are3 and half inches either side of that or 9cm if metric suits and then from those its another 7 inches or 18 cm give or take couple mm, hope that helps
- Darren
Co. Westmeath
Thanks for that Guys. I just don't want to make a mistake, and have too many holes in the car. I'll give that a go .... Cheers Darren
Cheers
Darren
Darren
