quick question
jamesb
Whats your location?: roscommon town
What Minis have you?: 94 mini cooper
Modifications: fully restored with a zeemax kit
quick question
Post by jamesb »
i have a 94 mini cooper and once you start it it ticks over perfectly then once it starts to get warm it starts to splutter as if it is out of petrol and then cuts out. any ideas what the problem is ??? or is there any one around roscommon that could take a look i cant figure it out thanks
Re: quick question
first place id look is at the vacuum pipes between the manifold & the ECU.
jamesb
Re: quick question
Post by jamesb »
keith wrote:first place id look is at the vacuum pipes between the manifold & the ECU.
what do i look for leaks is it? thanks
molly the mini
Re: quick question
Post by molly the mini »
Pm'ed
jamesb
Re: quick question
Post by jamesb »
molly the mini wrote:Pm'ed
what does Pm'ed mean ???
Re: quick question
sorry, yea. the pipes and rubber joins get very warm and crack with age, leaking. take the vacuum pipe off the ecu and you should feel a good vacuum at idle, warm.
jamesb
Re: quick question
Post by jamesb »
thanks i'll try that cheers
Re: quick question
It means you have been privately messaged by a member and this message can be found in your inbox
jamesb
Re: quick question
Post by jamesb »
sorry new to this site thanks.
Re: quick question
jamesb wrote:sorry new to this site thanks.
No need to be sorry :D
Welcome to the forum :D
Re: quick question
Welcome along James,good luck with your Mini.
Users browsing this forum: No registered users and 22 guests
