Brakes?
Ciotog
Whats your location?: Monaghan
Brakes?
Post by Ciotog »
I want to put disc brakes on Jules when I start rebuilding. Here is a pic of the master cylinder that I removed from the car and I was wondering what I need for a disc brake set up? I have the hubs, calipers and discs I just need to know how to convert from this master cylinder to a servo type.
Re: Brakes?
you do know that you don't HAVE to have a servo?
Infact personally I prefer the feel of my brakes without a servo, so I took mine out
Ciotog
Re: Brakes?
Post by Ciotog »
I did not know that. So can I use the master cylinder I have for a disc brake set up??
Miniquip
Re: Brakes?
Post by Miniquip »
The master cylinder you have for your car is known as the yellow band dual system master cylinder, this was first fitted around late 1977 on the then drum braked minis. It continued in use along with a couple of derivatives of the same system until the arrival of the Servo as standard on the mini in 1988. In conclusion it is perfectly adequate to run the disc brake set up your considering, even uprate 4 pot calipers if you really wanted to. as above the servo system will allow you to get more brakes for less pressure, but you won't have the full feel of the brakes, and I also prefer to run the mini without a servo.. (it is really only an assistant when it comes to braking, though due to the set up, car that have it fitted have virtually no brakes when the engine isn't running)
Ian
MINI QUIP
http://www.mini-quip.co.uk
Ciotog
Re: Brakes?
Post by Ciotog »
Good news. one less thing to buy. Cheers Ian.
Where are you based Ian, I'm in Monaghan so probably not a million miles away and I'll be needing parts soon :).
Miniquip
Re: Brakes?
Post by Miniquip »
Not a million miles away as you say...
I'm about 25 miles to the east of Newry for the time being.. may be moving base soon, but going to be here for the next wee while... I do offer a courier service which gives you up to 24kg to anywhere in Ireland for only £11.00.
Opening hours are going to be changed very soon too as I'm only going to be available from 10am to 1pm on Mondays and Tuesdays from now on...
Chat soon
Ian
MINI QUIP
