Rear Passenger Lights
My rear tail light doesn't work. It could be a fuse problem/circut problem or it could be that the lights need replacing. I have a new set of rear passenger lights and I wanted to know how much work is involved in fitting them i.e. do I need to take out the petrol tank? Any advise is welcome.
Yes you have to remove the petrol tank to remove and refit the rear lights.
It is fairly rare for the light unit itself to give problems, its usually the bulbs or the connections.
Check the plastic black connection at the light, you should be able to reach it between the tank and the light body. If you have a circuit tester, see if you have power there.
Are all the lights at the back not working stop/tail/indicator/boot light ?
