Minitastic spring suspension setup
- CLUBMANGT
Here is my new spring setup . I was going to go for the minisport smootharide but have heard very bad reports about minisport customer service and delivery lately so I opted for a step into the unknown. I got the 78mm fast road springs from Bert (cheers mate) and Yosuke Yamamoto at Minitastic supplied the rear spacers and ride height adjusters . They are machined and polished not cast, it will be interesting to see how she rides(whenever I find the time to build it )
Re: Minitastic spring suspension setup
looks nice and shiny Tony!
I'd been toying with this idea for a while but had heard that even the soft springs make for a more harsh ride,
Will be interesting to see how you get on?
Keep us posted
Keep us posted
- CLUBMANGT
Will do Macker , I have spoken to a couple of people with them, mixed reports but all seem happy enough. All in it only cost me 110 yo yos so worth a punt I think a ?
Had mine in for a couple of years now, although I'd never go back to rubber I wish that they did a front/back set with a bit more stiffness in the front rather than one size fits all. I would also go with the lowered rear shocks over standard as they would of given better ride height adjustment. But none of that detracts from the fact I haven't been scared of a speed hump for ages they definately take the thud out of mini suspension.
How to you get the front springs in?
- purplehaze
thats a nice little setup, 110 yoyos, i want
briain wrote:How to you get the front springs in?
I'd say it's possible to get them in when you have the hi-lo turned down the whole way.
The Marcos Graveyard wrote:briain wrote:How to you get the front springs in?
I had to take the top arm out, fidley but worth it.
- Whats your location?: Limerick, Cork and Galway
- What Minis have you?: 79 layland
72 morris - Location: limerick
Watching this closely but i have one question that someone may be able to answer for me.
How are the springs help in, is it just the weight of the car that holds them in place.
what happens when you go over a bumpy road or when car is lifted on a jack, do they move about i.e when suspension if relaxed.
Danny
Danny
- CLUBMANGT
The compression travel limit is controlled by the shock as with cones.
ah ok,
so basically if you get lowered ones you can't used standard shocks.
The springs are direct replacements for the rubber donuts in the standard Mini.
The compression is controlled by the thickness of the wire in the spring and the number of coils.
The shocks only control rebound in that they dampen the force of the returning spring.
The springs are under tension at all times. Once fitted to the car they will never be loose even if jacked up, the droop of the suspension is determined by the free length of the shock.
Lowered shocks or rather dampers are shorter and as they are bolted to the shell and the swing arm they wont let the swing arm drop as much as standard.danny wrote:ah ok,
- Whats your location?: Donegal
- What Minis have you?: Austin Mini City 998
Clubman GT in April you had aquired asuspension set-up but hadn't it yet installed or tested. What has happened since. How did it work out. Vincie
- CLUBMANGT
The car is still at the same stage I am afraid I just dont have the time at the moment to get near it . I have contacted Rob my welder who is due to fit all the new panels soon. I have all the parts I need , I even have all the paint . Sadly there is only 24 hours in a day and you go to sleep for some of them .
- Whats your location?: ramelton co donegel
- What Minis have you?: 1980 mini 1275 bord to 1480 1989 mini 1000 1992 mini open racing and 1984 mini 1000 automatic
- Modifications: 1275 fully rebuild fast road cam rebord biger pistons ported and rolished proforminse timing twin carbs proforminse spark plug leads sports coil and ditriber
CLUBMANGT wrote:The car is still at the same stage I am afraid I just dont have the time at the moment to get near it . I have contacted Rob my welder who is due to fit all the new panels soon. I have all the parts I need , I even have all the paint . Sadly there is only 24 hours in a day and you go to sleep for some of them .
did u get the springs fited yet wat they like
- CLUBMANGT
I am only now starting to build up the rear frame now so it will be some time before I can see if its any good but I will keep you posted ok
- Whats your location?: Seaforde, Ballynahinch, Co. Down
- Region: Northern
- What Minis have you?: 1961 Austin 7, 1988 Mayfair, 1964 Van, 1981 van, 1976 Pick-up, 1980 Pick-up, 1968 Wolseley Hornet, 1978 1275GT, 1986 Rally special
I installed a set of springs to a customers car here and on the test drive was extremely impressed at how the car rode. Very compliant, a little softer than a car on new rubber cones (I fitted the blue road springs), and although it did roll a little more than the standard cones on the corners, the grip and control levels were as I would normally expect...
Someone asked above how the fronts were installed, they are replaced exactly the same as rubber cones as there is a threaded section in the support plate which the cone compressor screws into, obviously the top arm will have to be removed to remove the cone and insert the spring as per normal cone change.
Anyone looking any advice or help with this give me a shout, also I carry in stock the full kit should anyone else want to fit them..
Ian
MINI QUIP
http://www.mini-quip.co.uk
MINI QUIP
- CLUBMANGT
I have the rearend all back up in place now ,I will fire up a few pics tomorrow I will then start to build the front frame and take some pics as I go
- CLUBMANGT
Afew pics as promised
