Battery problem
1980 Clubman GT - Contact:
Battery problem
Looking for some advice, I keep coming out to find my battery dead. I bought a new one and same thing has happened again. I thought it was new radio I connected but disconnected this and still happened? Any ideas
- Whats your location?: ballytore,kildare,ireland
- What Minis have you?: 1972 mini automatic
- Modifications: spax back shocks
rc40 back box - Location: kildare
Re: Battery problem
alternator could draw power which means its gone
Drumbrakes:going fast but aint stopping
Re: Battery problem
What happened to me last month was that the earth lead to the battery was badly worn. Changed it and no problem.
Re: Battery problem
Ya that lead not great Billy might try that thanks
Re: Battery problem
I had a similar issue with the battery going completely flat every now and then, turned out to be the positive from the battery that runs under the car, at the front where it goes up into the engine bay there was a metal clip with a bolt to hold it to the body. The clip had probably scraped over a lot of speed bumps over the years, as the front edge of it was as sharp as a blade and had cut into the cable. It was earthing, but only sometimes, never noticed it driving.
- Whats your location?: dublin ballinteer
Re: Battery problem
that haden to me an d my radio siint in my mini but i thurt that it was the amp and the two sups in the back
Re: Battery problem
I took out radio but made no difference
Re: Battery problem
with everything turned off, take the earth lead off the battery, put a digital multi-meter between the negative battery terminal and the earth lead, measure the current flow. it should be 0 (or *very* near 0)
if its not 0 (or *very* near 0) keep unplugging things and looking at the meter. thats a way to find whats drawing the current.
Dont try starting the car with that meter in place. you will fry your meter.
Re: Battery problem
Thanks will try that
