Moderators: spud1979 , The Marcos Graveyard , Moderators
daveq
Posts: 50 Joined: Tue Sep 01, 2009 9:45 pm
Post
by daveq » Sat Jun 18, 2011 9:31 pm
What's the general consensus on blocking up the vents?
I found a large area of rust around one of mine and wondering whether to repair it or just block it up?
Posts: 2118 Joined: Tue Jul 18, 2006 11:15 pm
Post
by keith » Sun Jun 19, 2011 1:24 am
you are going to have to weld metal in there anyway, i'd repair it then rust-proof like a mad thing!
Posts: 1076 Joined: Fri Oct 23, 2009 8:59 pm
Post
by CLUBMANGT » Sun Jun 19, 2011 8:08 am
I blocked mine up years ago . I used alloy plate .
Posts: 2680 Joined: Thu Feb 10, 2005 9:44 pm
What Minis have you?: 61 van,68 MKII, 75 Clubman estate, 80 1275GT 91 RSP Cooper
Post
by kerryminigringo » Sun Jun 19, 2011 7:18 pm
You can get an inner flitch repair panel which you can cut and repair the rust.This is a common rust problem on Minis with fresh air vents and personally speaking I would not block them up as they are very useful on a warm day and as near to A/C as you will get on most Minis.The panel is not expensive as well.
http://www.somerfordmini.co.uk/eshop/in ... cts_id=119
Post
by CLUBMANGT » Sun Jun 19, 2011 10:18 pm
A block,em up and roll the window down
des
Posts: 69 Joined: Wed Jul 21, 2010 1:42 pm
Post
by des » Mon Jun 20, 2011 9:08 am
My 73 has the vent holes, but blocked by a round factory fitted panel, held with about 6 small screws. So blocking it should not be a problem.
