elecrtic problem
elecrtic problem
yet another problem.....my horn and dip light does not...i ve checked the fuses and its working fine,.....i have noticed once or twice thathorn/diplight arm has smoked once or twice before..could i have blown the circuit...i cant beep at those naughty drivers and its annoying the hell out of my... any iders anybody
- Merlin
high brian. Your most probly right, your switch unit has burned out look enuf it is real easy to replace just order one from mini spare's. Remove the steering wheel. Then with your new switch gear beside the old one chande the plugs from one to the other, screw it back down steerining wheel back on and your in buiness.
- Merlin
- Merlin
