HELP NEEDED
craig_farrell
Whats your location?: Tinryland, Co. Carlow Ireland
What Minis have you?: 1968 mini cooper mark 2
Modifications: none shes bog standard.
HELP NEEDED
Post by craig_farrell »
hello i need some help.
i need to find a picture of a under view of a 1968 mini or similar or even better a view of the rear subframe to see where the brake pipes should be as i have no brakes and the problem is the rear drivers brake i dont know exactly what is wrong but there was a lump of fibreglass wrapped around the pipe where it is leaking.
any help would be appreciated,
thank you.
she may be rotten but shes still bappin!
Goose
Re: HELP NEEDED
Post by Goose »
Change the leaky brake pipe for a start. Someone tried to repair the leak with fibreglass I'd say :? .
If you cant get a picture from someone, try a Haynes manual. Might be helpful.
Is it leaking fluid from the Brake cylinder ?
Re: HELP NEEDED
craig_farrell
Re: HELP NEEDED
cheers lads.
nope its not leaking from the brake cylinder.
tried the haynes manual couldnt find anything helpful.
Re: HELP NEEDED
Is it the copper brake pipe or the rubber hose that is leaking ?
craig_farrell
Re: HELP NEEDED
copper brake pipe
