Can't get engine to run right (metro 1275)
just_st3v3n
Re: Can't get engine to run right (metro 1275)
Post by just_st3v3n »
woody wrote:Backfire usally means timing or if extremily lean detonation. I'd get it tuned sooner rather than later before any engine damage.
An Aussi Moke would be good for the beech Steve 8)
yep actually seen one of them buzzin and around traffic on the freeway, was trying to keep up to follow him and steal it but he was a goner :P
backfire through the carb or from the exhaust??
i had it set around 10-12 degrees with +- 1000 rpm....
some day....
Jozi
Post by Jozi »
I'll get dad to advance the time by 10-12deg and up the idle a little although it runs fine the way it is just needs a tiny bit of choke for a few second on startup.
It's hard to say if it is backfiring, the exhaust or something is also making a banging noise so hard to tell. How do I know is it from the carb?
just_st3v3n
exhaust box is hitting the spare wheel well... try adjustin it by loosenin up exhaust clamps and try rotate it slightly............ you'd know if its back firing through the carb trust me ;)
some day....
Jozi
Post by Jozi »
Dad had a go at it yesterday but reckons maybe it just all needs to come of and be re-done. He mentioned something about someone welding a bracket to it and because of it there's not much adjustment...
just_st3v3n
lol
weld up a new bracket then :P
some day....
Jozi
Post by Jozi »
If I have to I will 8)
He already advanced the timing to about 12deg.
mad4mini's
Whats your location?: dublin
What Minis have you?: 191 mini city
Modifications: none yet but buster will have plenty done to him after the resto :D
Post by mad4mini's »
if you dont mind me asking how difficult was the metro conversion? was it crazy money?
just_st3v3n
the metro engine is practically the same engine as a normal mini one, mg/rover took over mini and threw the engine into the pre 1989-90 metros. the only difference would be the crank, camshaft and some other parts im not sure about..
so realistically it shouldnt cost much/anything more than getting a normal mini engine..
i done the swap myself in about a day or so, its a great learning curve and with the help of a haynes manual and a few people from the club it isnt all that hard to do.
im sure someone can explain more on the metro engine..
steven
some day....
The mini and metro A+ series engine and gearbox are basicly the same except for the engine mounts which are located on the ends of the gearbox. Its simply a matter of unbolting the mounts from the unit comming out and fitting them to the unit going in.If your upgrading to a larger capacity engine you may need to change the exhaust manifold unless you have already upgraded this.
mad4mini's
sounds simple enough. is there any problems with the wiring loom? i was thinking if i was doing the swap for a metro turbo i'd bring the wiring loom and brake across too.
Sorry Metro Turbo is a whole different ball game, look here before even starting
http://www.turbominis.co.uk/forums/index.php
You really need to know a bit about mechanics before attemping this, Ihave one 20 years and its nearly running right :(
i'm in the middle of a turbo conversion but i've gone a different route to woody, and its a pain in the t1t5:!: :!: as he said do a lot of research first, you will need to fit a bulkhead box aswell
mad4mini's
I'm only thinking about it at the minute. prob wont happen for ages if it ever does. will get loads of research done for now anyway :D
Miniquip
Post by Miniquip »
Not sure if you turbo guys were aware of this, but there is a manifold kit available for the mini that allows the fitment of the turbo to the mini WITHOUT making ANY bodywork modifications.... The manifold allow the fitting of the Garrett T2 turbo kit and can give around 150bhp from the A or A+ motor.... Just need to have a well sorted gearbox to take it....
Any more information required give me a shout
Ian
MINI QUIP
http://www.mini-quip.co.uk
yea its the mirage kit, do you stock them???
Miniquip
Post by Miniquip »
I have supplied one kit which was a very tasty looking piece of kit and apparently a great fit... (I'd have to check the current price if you wanted a set)
The guy I got it for still hasn't got his out on the road, but only as he is finishing his degree and hasn't completed the last few bits on his car 1993 Italian job if I remember correctly
Ian
MINI QUIP
