wireing up a radio
yellowminiman
Whats your location?: celbridge co kildare
What Minis have you?: 92 city and 83 leyland 1000
Modifications: zeemax kit 1330 engine
wireing up a radio
Post by yellowminiman »
i have no radio in my 83 leyland and im fitting a new one i had lying arround i need a live, and a switch live and an earth .the earth is handy but where do i take the lives from
jocelynn
Re: wireing up a radio
Post by jocelynn »
take the permeant feed from the brown wire on the ignition and the switch is the green with white strip
yellowminiman
is that on the wires going into the ignition barrel
steeo
Post by steeo »
That's it but make sure to put an in-line fuse on the 2 live's going to the radio.
Miniquip
Post by Miniquip »
I always pull the live and switched feeds from the standard fuse box, simples......
Ian
MINI QUIP
http://www.mini-quip.co.uk
Miniquip wrote:I always pull the live and switched feeds from the standard fuse box, simples......
second that: theres a couple of spare terminals there usually and its a lot easier to reach than the ignition. IIRC the "switched" is colour white.
