flywheel puller
DAVEY_C
flywheel puller
Post by DAVEY_C »
hey lads and lasses, trying to take the flywheel off my 1275 is getting the better of me, im after going through a couple of pullers and 1 broke this morning :evil: .... not only that but i busted my housing too :evil: :evil: .....
does anyone know where i could possibly get a decent flywheel puller around the kildare/wicklow/dublin side of the world??
thanks in advance for any help
Re: flywheel puller
Without sounding smart the first question is did you remember to remove the washer.
Make sure the three bolts are equal lenght when screwed in so its pulling dead straight.
Leave it under tension for a few hours and then come back and bang it.
Is it in the car or out?
Re: flywheel puller
I you want to throw your engine ina car and spin down to me i have a kad pullers which should get it off,Bert 0858445677
GTM Coupe
Re: flywheel puller
Post by GTM Coupe »
I've also got one Sikes Pickavant, in Wicklow, Coynes Cross
DAVEY_C
Re: flywheel puller
Post by DAVEY_C »
hey woody, is that the lock tab washer? yea i removed that and all bolts were put on at equal lenghts. tried banging the puller bolts and the flywheel through the starting motor hole which only gave me more work, at one stage she was left under tension for 4 days and still not a budge, i supose the heating/quenching way might be worth a shot?... it still has a puller on under tension but the main bolt lost its head haha.
bert and gtm
thanks for the offer lads, i still have her under tension so i might try the heating/quenching today and hopefully that will work... if not i may give one of you's a shout.
GTM Coupe
Re: flywheel puller
Post by GTM Coupe »
What type of flywheel is it, some of the billet steel ones from the UK had a habit of welding themselves to the crank, unfortunatley the only way was cutting it off, trust me with a billet crank this was an expensive option. Seen more than my fair share do this. Just a quick check when you took off the lock washer and tab washer behind the bolt then replaced the bolt you did leave it protuding from the face of the flywheel say 3-5mm.
DAVEY_C
Re: flywheel puller
Post by DAVEY_C »
wahay after a bit of heat she popped, its a standard metro flywheel. i didn't use the bolt with the puller because the laser kit comes with like a block of round bar for it. the lump that broke off i have attached a pic of... can anyone say if its repairable or scrap?? are there replacement items redily available? are mini and metro ones interchangeable??
thanks for the help.
nutterboy
Whats your location?: south Dublin
What Minis have you?: 91 cooper
Modifications: A few bits here and there
Re: flywheel puller
Post by nutterboy »
Hi davey I remember Reading on another forum if the housings your swopping are both A or A+ it should be ok but one of the lads on here would know for sure. I did the exact same damage as you but not as severe as for buying one somerford mini should have them, doubt they'd be cheap though
jocelynn
Re: flywheel puller
Post by jocelynn »
if u are stuck for a housing i have plenty of them here
087 2597085
Re: flywheel puller
There is a difference in the size of idler bearing
DAVEY_C
Re: flywheel puller
Post by DAVEY_C »
thanks andy, i gave it a good clatter haha
jocelynn, would you have a metro 1275 housing??... i will try and find out if a+ mini housings will fit and let you know how i get on.... thank you for the offer
TMG, i take it the a+mini won't fit mine?
Re: flywheel puller
You can change the bearings from the damaged one over to the new one but you need a special blind bearing puller to remove the old bearing and sleeve without damaging the casing.
Re: flywheel puller
All Metros are A+ as is your housing but I think yours is SPi or MPi as it has a crankshaft position sensor and I don't belive these were ever fitted to Metros. If your running injection you'll need a housing with the sensor
GTM Coupe
Re: flywheel puller
Post by GTM Coupe »
The Marcos Graveyard wrote:You can change the bearings from the damaged one over to the new one but you need a special blind bearing puller to remove the old bearing and sleeve without damaging the casing.
There is an easier way to remove the bearing, find a socket that is as close as possible to the internal size of the bearing, then pack the bearing full of grease, hold the socket over the bearing and hammer it in, the pressure from the grease build up will force the bearing out, done it loads of times so i know it works.
