So whats the biggest PIG of a job you have done on your mini
I spent 4 Hours under the car yesterday getting my Manifold off the car, it was seized at the Y piece, Not even when glowing red hot would it come off, I game up and cut it out causing as little damage as possible.
Others have been Engine Mounts ( a whole day of fiddling, levering , hitting to get 1 bolt in), Seized Balljoints, the Roll Pin and THAT bolt on the Bell housing.
Anybody have any others?
- antodeco
Re: So whats the biggest PIG of a job you have done on your
Used to be that fecking brake switch. Had a broken back doing it. That was until someone told me an easier way of doing it!
Removing the split pins from the clevis pins at the bottom of the master cylinder push rods is a fun task.
To make things a bit easier I now use R clips instead of split pins.
Dont forget the old bypass hose on the road side .
DOUGAL
[quote="The Marcos Graveyard"]Removing the split pins from the clevis pins at the bottom of the master cylinder push rods is a fun task.
To make things a bit easier I now use R clips instead of split pins. [/quote]
Always put a bit of copper grease on the pin when putting it back in and along with the R clip makes things alot easier when you are in the inverted position again.
Im liking some of the tips in this! , I havnt done it yet but the spring behind the servo looks like it has potential too. As do the Bolts for the rear subframe into the heel board!(thank god I dont have to go there, YET!)
- Whats your location?: near mondello
- What Minis have you?: 86 saloon
65 clubby estate :) - Modifications: b16a on the way
trying to find a new clubby front bumper
as above,trying to get that split pin out was by far the worst job i had to do on the car when both master cylinders had to be changed!
Cant wait for this pin!, looks like I will have to get some R pins , I need to replace the plate under the clutch master cylinder.
oh that pin is a nightmare but usualy comes out a bit easier the more you swear at it lol.... must stock up on R clips too, handy tip....
Theres an easier way ?? Repaired my switch and got a new one but have been avoiding fitting it till it was necessary.antodeco wrote:Used to be that fecking brake switch. Had a broken back doing it. That was until someone told me an easier way of doing it!
changing the rad on the roadside, only to discover that my "spare" was from a 998 and the bottom hose would *not* fit. This was at night, 20k short of Malin Head.
and as TMG said: clevis pins under the dashboard......
needle nose pliers, a flat blade screwdriver and tough gloves for when it bites back.kona wrote:Im liking some of the tips in this! , I havnt done it yet but the spring behind the servo looks like it has potential too. As do the Bolts for the rear subframe into the heel board!(thank god I dont have to go there, YET!)
Depending on who fitted it, the jubilee clip for the bottom hose is a bitch if like me, some genius befor mounted the screw facing the Subframekeith wrote:changing the rad on the roadside, only to discover that my "spare" was from a 998 and the bottom hose would *not* fit. This was at night, 20k short of Malin Head.
- EAMOSPUD
- Whats your location?: The Rebel County ...
- What Minis have you?: 1972 mini 850
- Modifications: None ( Well nearly none... ) twin 1"1/4 su carbs , KN filters, cooper freeflow manifold, RC40 single box side exit.
Ya removing split pin from clevis pins. It does not help then when I manage to lose one of the clevis pins in the bulkhead area in the small gap where master cyclinder arms drop down. Pin slipped in there . 30 mins later with the aid of small mirror. Magnet and small nut retrieving tool. Got it back.
I just love working on my mini.
- CLUBMANGT
Is it just me but I dont mind that split pin now who has had a go it getting the sheer bolts on the steering column out from the dash top side
- armo
imoc member - Contact:
stage 1 kit (exhuast) spent 3 hours yesterday trying to get it to fit pain in the hole every time the engine comes out thats the part i dread all done now and never coming off agen
- Miniman
- Whats your location?: Cavan
- What Minis have you?: 1966 850,92 city,98 2.5turbo R33 Nissan Skyline and a 1979 Mini Clubman
- Modifications: To many to list!
Deseeming a mini is always fun!
Bending the rules,and ruling the bends,Since 1959!
In the middle of one now you won't come accross too often, swaping the turbo with the engine in the car.
Where is the turbo mounted?
Oh If your Flywheel is on tighter than normal, its a Pain in the ass, and if you dont have much time, its not something you want to run into. :/
- Kenneth Murphy
at the back of the engine......kona wrote:Where is the turbo mounted?
If you undo the steadies and mounts counld you not tilt the engine? Although Id be taking it out with that much effort!.
- hughesmarkie
[quote="woody"]In the middle of one now you won't come accross too often, swaping the turbo with the engine in the car.[/quote]
Agree... That's a pig if a job and the bolts on the elbow are always a nightmare from the heat!
Heres the reconditioned turbo
And heres where it goes, below the exhaust manifold
I decided to go for the exhaust clamp rather than the elbow and thats gona be a right pig to get back on. Heads off gettin skimed at the moment so I'll find out Saturday if Ican get it all back in without removing the engine.
