Went to visit Martin today to see how progress was coming with the Munster Mini.
Here's the original front panel with damage and rust all along the bottom of it:
And here's the replacement Heritage panel:
The subframe is out and will be cleaned up and painted
Rust on the inner ashtray panel thanks to the infamous wide windscreen rubber
Inner wings showing drilled out spotwelds
And the engine bay cleaned up from split brake fluid
The passenger side had taken a slap at some point in the past and the wing had been replaced
We held up the new front panel to the car and you can see the huge difference between the factory wing on the drivers side and the replacement spurious wing on the passenger side. You can also see where the aperture for the headlight had been butchered to adjust the lights. The aperture is a different shape.
Needless to say we are now replacing the passenger wing with a genuine Heritage panel.
