Retro rally car
Re: Retro rally car
thats givin me an idea :idea: :idea: :idea: :idea:
Re: Retro rally car
do the inner wings have to be modified in any way to fit the engine in???
Re: Retro rally car
No, that is the beauty of this conversion.
There may be issues with the alternator mounting position in a roundnose, but both Joe and myself are fitting the engine in Clubman fronts which has more room all round.
Re: Retro rally car
ok. i've just purchased my new engine...............1.5 dohc pulsar engine. same dimensions as the 1 litre and 1274cc,......i'll fit the alternator somewhere!!!!!
Re: Retro rally car
Will u post a picture
Re: Retro rally car
QG15DE is the engine code for that engine, seems to be the same that was use in the nissan almera, dunno about that one, i looked into it when one of the lads mentioned it.
Re: Retro rally car
haven't collected it yet. i've been on to a few lads that run them in micra hot rods. they say there the same the 1.6 is bigger. i'll post a pic when i get it.
Re: Retro rally car
must call down and see this for my own eyes! Great Work! :D
Re: Retro rally car
Progress, :D :D
Re: Retro rally car
joebe1 wrote:Progress, :D :D
enlighten us!!
Laurna77
Modifications: Metro engine
Re: Retro rally car
Post by Laurna77 »
Any Photo's Joe
Re: Retro rally car
Coming along nicely. Engine mounts are fabricated and CV clearance issues are sorted.
Won't be long now 8)
minivillian
Re: Retro rally car
Post by minivillian »
Progress. Slow, but deliberate....
Overall view,
Brackets during manufacture....
Gearbox mount tacked and waiting to be trimmed.
Drivers side mount.
Driveshaft coming out thrugh the subframe. You can make out some of the grinding to accommodate the boot. The second picture shows the view from top subframe mount looking down to the back of the gearbox. This section has been reinforced.
minivillian
Re: Retro rally car
Here's one for the health and safety conscious out there:
I suppose at least he's wearing safety glasses!!
Re: Retro rally car
The box section at the front seems to work out far better than the original. Much stronger all round.
Re: Retro rally car
Its stronger all right, but in your case it ll be sound, i m goin to get round bar tomorrow to run underneath the engine back to the legs where the subframe mounts to the floor,
For some reason yours is way easier to get in and out of the subframe, but it comin on, engine will be in tonight so will have photos later,
minivillian
Re: Retro rally car
Tip of the key now and she is away :-)
Laurna77
Re: Retro rally car
Post by Laurna77 »
Coming along very well Joe, Can't wait to see it on the road
Re: Retro rally car
Bumpers crooked.
minivillian
Re: Retro rally car
View of rear engine mount
Top view of the front mounts
Radiator view. The front bracket needs to be trimmed before it will sit just right.
minivillian
Re: Retro rally car
Got at the interior to try and get the dash sorted. The heater needed to have a new mounting bracket fitted.
And all that left us with this:
Got the bracket to mount the steering wheels sorted too. Welded in a new cross-member between the front uprights of the rollcage. This will support the heater as above, the steering column and the bottom of the dash will also be fixed to it to secure it fully.
Mounted
Done!
Re: Retro rally car
Great progress Joe.
minivillian
Re: Retro rally car
Subframe with a substantial amount of welding wire added. Along with more strengthening.
Now time for tea!
Re: Retro rally car
How much clearance is there for the exhaust where it goes between the sump and the front of the subframe ?
Seems to be plenty of metal left around the lower arm shaft.
Re: Retro rally car
There enough to get the original pipe down with plenty of clearance, but thats because i ve removed the 1 inch piece from the front, i m happy enough once i get all the welds cleaned up, colin can be let out :D recked though
Users browsing this forum: Google [Bot] and 13 guests
