Brake Upgrade
- antodeco
Brake Upgrade
Hi All,
Im looking to upgrade the brakes on the Clubman GT. Its still standard brakes on it, which are scary to say the least! What would be the best to go for? I would want whatever would be the best brakes, so I am open to suggestions, as well as prices. Its running on 10s.
- BERT
Re: Brake Upgrade
Probably KAD 4 pots but not that cheap
- hughesmarkie
Re: Brake Upgrade
Alot of people swear by the minispares 4 pot alloy calipers, I found them to be great calipers and a cheaper option that the KADs.
http://www.minispares.com/Product.aspx? ... 325&title=
Mark
Mark
- dayoungfella
- Whats your location?: Stepaside, Dublin
- What Minis have you?: Mk1 Racer and Mk2 CKD
- antodeco
Re: Brake Upgrade
Thanks for the replies guys. In relation to the minispares ones, is it a case of buying that kit than 4 vented discs? That would be around £500, so around €700, plus another bit on top for installation?
I was going to look at a rebuild, but my thinking is, spend the money now and save in the long run..
- dayoungfella
Re: Brake Upgrade
I have 100bhp engine in my Mini with Cooper S brakes and dont find myself wanting/needing more braking power. If i do, ill upgrade to a set of Carbon Lorraine pads which are meant to be amazing.
Braking power comes down to your tires too though. I run a set of Avons on mine which probably help with the brakes on my car.
Neil
- antodeco
Re: Brake Upgrade
I need to check the tyres actually. They have decent grip. I've had a few scary moments braking, so wanted something better!
- CLUBMANGT
Re: Brake Upgrade
Cheap option that works (I have done it so I know) new pistons, seals and fast road pads .
- antodeco
Re: Brake Upgrade
Any ideas where I can get it done? I'm not very good at any mechanical stuff
Re: Brake Upgrade
I run a set of KAD 4 pots on my own mini and ran them for ages with greenstuff pads in but was never overly impressed with the brakes from cold, and heating them to the right temperature took a little spirited driving,
i changed to Carbone Lorraine pads a while back on a suggestion from Merlin (Paul Hickey, Hickey race engineering) He'd be the man to do it for you too!
and Oh My God! do they work well!
the first time i stood on the brakes i nearly flipped the car!
from this and taking into account that you have already got the standard set up, my suggestion to you would be to get your existing set up rebuilt and get a set of Carbone Lorraine pads, i think that would be more than enough to stop you whenever you wanted
- sid
- Whats your location?: Bray
- What Minis have you?: 1430 Cooper
- Modifications: Not enough!
Re: Brake Upgrade
Are ya able to get the Carbone Lorraine pads for 8.4" setup?
Where ya getting them? Mini spares dont seem to have them!
Re: Brake Upgrade
http://www.cl-brakes.com/catalogues/auto.php
for a full listing of applications from CL brakes
mini cooper s - year,63-71 - 5001W43T14
- Merlin
Re: Brake Upgrade
I have Carbon Lorraine pads in stock for, KAD 4 pot, mini Sparea 4 pots, Cooper S 7.9,
mini 8.4. I have All the abouve in CR5 which is fast road/ track day pad. They are quite expensive but very worth wile.
I have fitted them to 8 road going minis At the moment and all reports are a masive improvment in braking from cold.
If your intrested in a set give me a call and we can sort you out,
regards
Paul.
regards
Paul.
Mk2 998 cooper (coming soon)
86 coupe quattro
Re: Brake Upgrade
as most peps are saying the s discs are up to the job.
on my 110BHP mini i had a set of rebuilt s discs, nothing fancy, no servo, ran the carbon pads and the road legal track day tyres.
put alot of cars to shame around nutts and Kirkistown.
As with everything else, before you upgrade, get what you have properly sorted first and then see if you feel the need to upgrade.
Stewart
Lucas, the prince of darkness
Re: Brake Upgrade
I have Carbone Lorraine pads on my bike, great pads compared to the standard, dont have them on the mini though, always found the standard servo and standard 8.4 setup to be more than adequate for me. Although my mates say they are shite, and I say the brakes in their civic etc are a bit too strong, just a matter of getting used to them i suppose if your coming from a more modern set up..
Re: Brake Upgrade
how are the C-L pads like for dust?
- Merlin
Re: Brake Upgrade
They are no more dusty than any of the performance brake pads out there.
Re: Brake Upgrade
Are you running a servo and if so have you cheaked its working properly. Tyres are just as important as brakes for stoping quickly.
