1980 Clubby
- BERT
Re: 1980 Clubby
Bought this the other day delighted with it,believe it use to belong to a club member?
Engine is a 1098
12g295 head (goes well)
Stage one kit
Head steady
Front Hi Lo's
few other bits and peices
First thing to change is the wheels!
Engine is a 1098
Stage one kit
Head steady
Front Hi Lo's
- joebe1
Re: 1980 Clubby
Beautiful car bert, best of luck with it.
Re: 1980 Clubby
Nice buy bert!i have to say i love clubbys
- BERT
Re: 1980 Clubby
Since you like them so much il give you a good deal on them!CLUBMANGT wrote:Cool wheels you should keep them
ordered a new set when i got home!
- DaveC
Re: 1980 Clubby
Very nice Clubman.
Who used to own it from the Club?
I reckon the wheels suit it though!
What wheels are you putting on it instead?
- BERT
Re: 1980 Clubby
10x6 minilights
Re: 1980 Clubby
Nice wheels but I agree with the change the minolites will be even better.
- StanO'Toole
1994 Mini Sprite - Contact:
Re: 1980 Clubby
Is this the one that was on Donedeal Bert? Looks well, well wear.
Re: 1980 Clubby
Lovely Mini Bert,slab noses are the biz.Love those wheels too.
- BERT
Re: 1980 Clubby
Ha!done the discs and bled the brakes and now its decided to start pulling to one side!
- Merlin
Re: 1980 Clubby
Stickeey Piston Berty did you change the pads ?
- BERT
Re: 1980 Clubby
They both pushed back easly, and i reused the pads as there nearly new,just cleaned them up on sandpaperMerlin wrote:Stickeey Piston Berty did you change the pads ?
- Merlin
Re: 1980 Clubby
ya happens some times on coopers some times when you push the piston back in a small amount of dirt goes back in with it which then cause the piston to cock in side the bore. just check for sings of a piston not pushing out.
If its not that im stumped did you do anything elce ?
- BERT
Re: 1980 Clubby
Na pulled out a few different 1275 engines to see which would take the least amount of money to get going
Re: 1980 Clubby
Good stuff Albert. So thats 2 of your last 3 Minis that have been yellow clubbies!
- BERT
Re: 1980 Clubby
Ye ,pulled the hanbrake out of the floor earlier!bloody minis!
- BERT
Re: 1980 Clubby
Looken a bit sorry for itself!
- BERT
Re: 1980 Clubby
Thats the result of leaving it sit in the bodyshop for the year!just washed it took ten mins to get it clean!
- CLUBMANGT
Re: 1980 Clubby
If you need a caliper piston or caliper for the clubby give us a shout off to the workshop to sort out me kads now (i hope!)
- BERT
Re: 1980 Clubby
You must be in the good books with the missus!
