Please look at my nuts !
Deadly Dave
What Minis have you?: 1990 Black Checkmate 998cc
Post by Deadly Dave »
I have a 1990 Checkmate that came new on Minilite style wheels. The problem I have is with the wheel nuts. The wheel brace dosnt fit them. They are 16.5mm across the flats. Do these look like the correct original nuts or have they been replaced at some stage please.
Deadly Dave Image
just_st3v3n
Re: Please look at my nuts !
Post by just_st3v3n »
the nuts are more than likely original and are an imperial size hence the ,5 .. .. think its 3/4'' imperial socket your looking for , correct if im wrong anyone...
some day....
that looks like part of a lock nut set to me?
I'm with Mr. Mack. Never seen nuts like that on a Mini. I'm almost sure there aftermarket.
kona
Post by kona »
I think they are 11/16 those nuts are standard, they came on my cooper too, they are just missing the cap that goes over the top.
kona wrote:I think they are 11/16 those nuts are standard, they came on my cooper too, they are just missing the cap that goes over the top.
thats what was throwing me, the little chrome cap :lol:
oel159
What Minis have you?: 1972 Mini
Post by oel159 »
It looks like one of the lock nuts off my 89 "racing green" which has a chrome cap to cover it off to make it look like the rest of em.
[quote="kona"]I think they are 11/16 those nuts are standard, they came on my cooper too, they are just missing the cap that goes over the top.[/quote]
Kona is spot on,these are Rover nuts with the stainless steel cap missing.if you don,t use a 11/16 socket,a six sided one is best,the nut will become rounded like the one in the picture and be quite hard to remove.
Deadly Dave
Thanks for the replies.
If I get an 11/16 wrench then it wont fit the jack, or was the jack 11/16 too ??
Deadly Dave Image
The nut is the correct shape not rounded. If you have the correct 6 sided imperial socket or wheelbrace you can remove the nut with the cover in place. If you use a slightly larger metric socket (like most tyre depots) it distorts the cover and it will not allow the proper imperial socket to fit back over it, it also losens the cover so it falls off like the one in the picture.I tried to find a chrome nut that would fit that wheel but I couldn't get one that sat right.
kona
Post by kona »
jack is 11/16 too. much easier to use a ratchet with the jack, as the brace i find hits the door and seat. ratchet does the job way faster.
Deadly Dave
So I need to get caps for all my nuts ??
Deadly Dave Image
No, you need new nuts.
Deadly Dave
NUTS :twisted:
Thanks for the help lads Image
Deadly Dave Image
