Hi after sorting gremlins with my iginition system i now find myself without any indicators. Its not the flasher unit as the hazard lights still work. anyone have any suggesitons where i can start ??
As far as i can tell all other electrics are working and all the fuses look OK
more technical assistance
- dayoungfella
- Whats your location?: Stepaside, Dublin
- What Minis have you?: Mk1 Racer and Mk2 CKD
At least on my car, the indicator flasher unit is behind the dash held by a spring clip to the frame. The hazard flasher unit was in the engine bay on the passenger side. I've done a bit of rewiring so both units are now in the passenger compartment as are the fuses (changed to blade from the original glass ones). Just too much corrosion potential in the engine bay.
