General unsteadyness and wandering.
Al the mod
Whats your location?: Lucan
What Minis have you?: 96 Equinox (Merlin)
Post by Al the mod »
Hey folks noticed awhile ago but never really thought much of it till it started annoyin the he'll out of me the mini is wandering from left to fight somethimes find it hard to jeep it between the lines on the lane (and smur it's not just my driving) also noticed if I pull away any way sharpish it has a wheels on the front of a trollie like feel to it any ideas cheers Al
Re: General unsteadyness and wandering.
What size wheels are you running ?
Al the mod
12x5. Also if you turn the wheel right when turning it feels like it's diving to the right witout effort to turn wheel. Would a shrunk suspension cone Cause this
Did you check for play in the ball joints/track rod ends/wheel bearings/radius arm bushes/steering rack ?
Al the mod
Yeah man had it on the ramp and no excessive play in anythin only thin o can think off is the front drivers suspension cone is knackard replaced the rears with hi Los and coil springs could it be possible I have them adjusted to high.
Did you only do the rears ?
What rate springs did you go for ?
You may have upset the sprung balance of the car !!
Al the mod
Yeah only done the rears didn have enough money to get fronts but gettin then this month hopefully.
Not sure what the springs where got them off p&l minis.
I'd say that's a lot of your problem, you've only half the job done.
jebus
Post by jebus »
I had that for a while in my focus. just needed the tracking and balancing done.
