NCT question
mini_sprite94
Whats your location?: just out side Mitchlestown.
What Minis have you?: 1995 Mini Sprite, Elmo.
NCT question
Post by mini_sprite94 »
hello! I'll be soon getting my Mini, and I'm switching it over to an Irish reg. car, thats means a NCT has to be booked for it too.
How does a mini do on emmisions for the NCT? are there any other real problems with a mini and the NCT?
Not a real big problem, Minis are good enough on emmisions, most garages will be able to adjust the mixture/timing to get you within the limits.
dayoungfella
Post by dayoungfella »
Is your car a 1994? Make sure it still has a cat on it and you shouldn't have a problem!
mini_sprite94
Thanks Marcos, how do they do that? how does that work? I'm new to minis, and cars is general, trying to find out more of the whys and hows, instead of just going "ok mr. mechanic make it go vroom vroom" I'm the nutter who'll be sitting there nodding as some sage mini nut shows me how the starter works! :D
You should get yourself a copy of the Haynes manual that covers your particular age of Mini, there have been a few editions and the older ones might not cover your model.
It has a step by step guide on maintenance and overhaul of all aspects of the Mini, from replacing a fuse to stripping an engine. You can pick them up fairly easy on ebay, should only cost a few quid.
mini_sprite94
Yea have the ould Haynes manual sitting on me shelf Marcos. will have a read of it again tonight.
Dont think it has a converter on it tho dayoungfella.
dayoungfella
You may have a bit of a problem there! Converters were neccessary on all cars manufactured after 1992....
Also, your car is more than likely injection and not carb so to make sure your car is running right, you can reset the ECU....can't remember exactly how to do it but I think you just leave the battery unconnected over night and it will reset when you connect it back up!
dayoungfella
Where are you located by the way?
mini_sprite94
dublin town, Terenure, sorry oul country habit of saying that.
Mark
Post by Mark »
If you need to borrow a cat for the NCT - I have one in my shed.
My car did immensely well in the emissions. Just everything else was a problem!
mini_sprite94
ahh sure I'd feel putting a cat on for good would be better. then i wouldnt have to worry about it again. but thanks for the offer Mark :)
Mark
Post by Mark »
Well I'd be willing to sell it to you too if you needed one. They are some ridiculous price new.
babycakes
Post by babycakes »
I've a 94 Sprite that went down on emissions as the previous owner removed the cat when the big sports exhaust was put on. Mark would the cat you have work on this. How much are you looking for.
mini_sprite94
Well seeing as Babycakes jumped on in there I'd have to go and buy one. do they affect the car, appart from emmisions? any makes or types stand out?
dayoungfella
Mark offered it to you first though!
They do hinder peformance a bit which is why people take them off in the first place...
There aren't any different makes or models...just Rover ones.
mini_sprite94
no its cool I'm doing mine up at the moment, all these part I expected to have to get. I'm also getting new belts for it. But thats the fun of a mini!
:D
I found this site,
http://www.cats4less.co.uk/home.php
mini sport have one too
http://www.minisport.com/classic-mini-s ... oduct.html
babycakes
Post by babycakes »
Apologies for hi-jacking your post, didn't mean to jump in like that.
You could be lucky with the NCT guy that tests the car. Although mine was a 94 they used the emission specs for a pre 94 car. It was only at the retest that they said it must have a cat.
Best of luck with it.
mini_sprite94
God dont worry about it Babycakes! :D
