Big Rattle...Any Ideas?????????
- Cooper-1275
Was heading into town this evening in my 1990 Mini 998cc when a very loud rattle started from under the front of the car ...not an engine rattle, it sounded like 1 of the front wheels was lose and about to fall off. Pulled the car over and both front wheels where tight, track rod ends and balls joints all look good.
Do they give drive shaft trouble or could it be something in the gearbox or maybe it's something totally different...any idea's what it might be
Jim
Jim
Re: Big Rattle...Any Ideas?????????
maybe your engine steadies need replacing, could be you exhaust rattling off the bottom of the bulkhead?
also could be a shock mounting, up under the front wings, grab the top of the shock and give it a good shake, any play and they might be the culprit
- Cooper-1275
Thanks Mackermacker wrote:maybe your engine steadies need replacing, could be you exhaust rattling off the bottom of the bulkhead?
Will check engine steadies and shock mountings, deffo not the exhaust.
Is it normal when you grab the inner joint on the drive shaft that it feels lose in the gearbox...it will sortta rock if that makes sense
wheel bearing
cv joint
shock mount
exhaust
brake pad down to the metal
it could be absolutely anything, WELCOME TO THE WONDERFUL WORLD OF "minis"
cv joint
shock mount
exhaust
- Cooper-1275
miniireland wrote:wheel bearing
cv joint
shock mount
exhaust
Thanks for the Welcome MiniIreland
i usually just ignore it and if the rattle stops then the part in question has fallen off......
- Cooper-1275
Come on Gareth, you da man that should have the answers I seek...any ideagareth wrote:i usually just ignore it and if the rattle stops then the part in question has fallen off......
- daniel garry
sounds bout right!! and if it doesnt stop the car working then it doesnt need to be there anyway!gareth wrote:i usually just ignore it and if the rattle stops then the part in question has fallen off......
- StanO'Toole
1994 Mini Sprite - Contact:
Drive her on and buy a loud sound system. Problem solved!
- Whats your location?: -
would it be something hitting of the fan blade?
dos it rattle when the engine is ticking over or when the car is moving?
- Cooper-1275
No stones in the dust sheilds.
Car has to be moving for it to make noise.
Got the car up in the air earlier today and noticed a nice bit of oil coming from the R/H driveshaft oil seal and there seems to be alot of movement in the shaft...do Minis give driveshaft trouble or can something happen in the gearbox that might cause the shaft to rock so much
- alexbrowne
- Whats your location?: Stillorgan, Co Dublin
- What Minis have you?: 1988 Austin Saloon
- Modifications: Sunroof and Spots.
I have the same problem i think. It is coming from behind the passenger side front wheel. Its just a rattle i would imagine something is loose around the brake housing or something. I have been meaning to jack it up and have a look. When i do ill tell you what mine is.
Car - 1988 - 998 Austin mini
What year is the car? MPI diffs give trouble.
- Cooper-1275
1990...998ccwoody wrote:What year is the car? MPI diffs give trouble.
- Cooper-1275
Any more thoughts any1
The inner CV should be tight, it sits in a bush in the diff housing and is not something that goes suddenly. Is the noise ther constantly? .Have you tried jacking the wheels and driving them slowly?
- Cooper-1275
Hey Woody,woody wrote:The inner CV should be tight, it sits in a bush in the diff housing and is not something that goes suddenly. Is the noise ther constantly? .Have you tried jacking the wheels and driving them slowly?
Thanks for giving me a shout...
Jacked the front of the car up this evening and it's all quiet but once the car is on the ground driving it's making a hell of a rack
It's now stuck in the air with the 2 drive shafts out of it and there's alot of play in the shaft that the drive shaft slides onto in the diff, especially the drivers side 1...What does that tell ya
Cheers
- joebe1
Diff bearins are shot i d say, does the noise get louder the faster u go
- Cooper-1275
I think sojoebe1 wrote:Diff bearins are shot i d say, does the noise get louder the faster u go
Sounds like the diff, unfortunitly its an engine out job so if your not sure get a second opinion.
