my lights dont work.....?
- just_st3v3n
- Region: Northern
okay im gonna keep buggin u guys till i get all sorted on my car :D
there seems to be a slight prob wit the lights and i dont know whether its a fuse a bulb or a switch or if i need to replace the whole lamp...
my parking lights come on no prob but the main lights do not, my head lights also work......??? how many bulbs is in the lamp and if one is broke can i just change it??
When you turn on the headlights to the first position on the main switch the parking light comes on, the second position on the switch turns on the headlight main bulb, then a flick of the stalk will light the second element in the main bulb and give you your high beams.
From your post I think it is your high beams that are not working, is it on one headlamp or both ?
- just_st3v3n
- Region: Northern
Check to see if you are getting power at the stalk on the blue wire with the white trace, this is the output feed from the dip switch, the solid blue wire at the stalk is the input feed which comes from the light switch in the dash, no power out but power in suggests a faulty dip switch, It might be possible to repair if it is only a contact problem.
Can you flash the headlights BTW ?
- just_st3v3n
- Region: Northern
