radio problems...??
- just_st3v3n
- Region: Northern
radio problems...??
i just bought a new stereo wit cd player but everytime i have it wired up it plays songs for about a minute and then the fuse coming from main battery supply keeps burning out???? have it wired up wrong? need a stronger fuse????
is it the fuse in the minis fuse box that goes or the one that came with the radio ,check the rating of both because if the minis own fuse is a smaller rating than the radio and it has other equipment being fed off it,then your overloading the minis fuse,it sounds like load cos if it were a short circuit it would blow straight away but the fact that it takes a minute suggests overload,you may need to look a getting a different supply if its a high powered radio cos cars with big ice usually have uprated altenators and an uprated battery or two,its all down to load
- just_st3v3n
- Region: Northern
- just_st3v3n
- Region: Northern
- just_st3v3n
- Region: Northern
The fuses that are standard in the car are rated for the size of cable in the car and should not replaced by larger fuses.The principle of the fuse is that if overloaded it will melt befor the cable, enlarging the fuse will allow the cable to melt before the fuse.FIRE!!. If your running some nice ICE look at feeding it directly from the battery with large cables and appropeate fuses.
- just_st3v3n
- Region: Northern
- just_st3v3n
- Region: Northern
- just_st3v3n
- Region: Northern
