nct
shaig_k
Whats your location?: kerry
What Minis have you?: rover mini mpi 1997
nct
Post by shaig_k »
is there any major parts on the mini that you have to look over before the nct
kona
Re: nct
Post by kona »
Bulbs
Battery
Headlight alignment
Tracking
Handbrake adjustment
Full Service
Check for corrosion.
E mark on the tyre
Spare tyre
Make sure all the seats are secure.
Give it a clean
Emissions you will find out on the day, its *usually* handy to sort on a standard car. If you have modded it, it gets alot trickier
shaig_k
Re: nct
Post by shaig_k »
cheers for that lad .never know i had to put in the spare tyre
Al the mod
Whats your location?: Lucan
What Minis have you?: 96 Equinox (Merlin)
Re: nct
Post by Al the mod »
Spare wheel isn a test fail if it's not there only in caseof taxi's
mgb1978
Re: nct
Post by mgb1978 »
The Ball-joints are a very common fail, most of the time you will get away with taking out a shim or two. Also radius arm play can sometimes cause a fail (but only if they spot it).
Oil leaks (but not if it is just a slight weep) are another mini problem.
My own approach is to put it through and then fix what they fail it for...I'm sure not everyone here will agree with this but at least you wont waste your time and money.
With an MPi engine emissions may possibly be a problem but dont lose sleep over it before you actually do the NCT.
Re: nct
I would get the lights set and do the tracking and get the front wheels balanced and let if off at that.If you want a mechanic to look at it Dick Mason in Tralee is a good man for minis.
Re: nct
don't forget to fill the washer bottle :lol:
Re: nct
Jack up each wheel and check for play, ball joints on the front ,radius arms on the rear, if you can feel any play the computer will deffo get it. visual inspection all lights and oil leaks, power hose engine. Check that car brakes in straight line . Fill and prime any rust hole no matter how small, a hole is a fail ,filler isn't.
Helen
Re: nct
Post by Helen »
Check your rear foglight is working! It's a new check on the NCT -- my bulb was gone & I hadn't checked it before the NCT.
marcexec
Whats your location?: Dublin 14
What Minis have you?: '84 Austin Mini 998, aftermarket softtop conversion (probably done in the 90's), BRG (a shade darker than original), rare headlamp rims with peaks (one piece), 3 piece wooden dash with 2x gloveboxes
Modifications: 12x fusebox, moved to interior, Hi-Los and Stage 1 kit, W&P Style arches, 12" minilites, 4x Wipac, T7 heater with special Y pieces, 7Ah motorbike battery in engine bay, Powerspark Distributor, reclining bucket seats bolted directly to floor, custom switchboard with MP4 player as headunit and small 20W amplifier, some burr pieces
Re: nct
Post by marcexec »
We have a '84 and there is no foglight - is that OK?
Lucas - Lord of the Darkness
mgb1978
Re: nct
Post by mgb1978 »
That's not a problem. They will only check the operation of fog lights when fitted.
marcexec
Re: nct
Post by marcexec »
Cool. 8)
Thanks mate, one thing less to worry about.
shaig_k
Re: nct
Post by shaig_k »
fail the frist time on small things here comes around 2 lost the fight but the war keeping on coming
Tommy C
Re: nct
Post by Tommy C »
What did she eventually fail on Seán ??
If you want to bring over your completed membership form to Clogherbrien, we'l be able to give it to the Club secretary for ya tmoro eve in Mizen save you posting it.
Tommy Jnr
Re: nct
marcexec wrote:We have a '84 and there is no foglight - is that OK?
Not ok, Rear fog lights are compulsory on all cars from 1st Jan 1980
mgb1978
Re: nct
Post by mgb1978 »
http://www.ncts.ie/pdf/nctmanual.pdf
Scroll all the way down to page 89 and you will see that "where fitted" fog lights will be checked.
Fog lights may have been compulsory on all new cars sold here since 1980 but there were a large amount of second-hand imports (especially japanese) that did not have them fitted.
So rather than force a lot of people to retro fit them the NCT have just decided to check them if they are on the car.
92Coop
Re: nct
Post by 92Coop »
Our 98 cooper, the "not working" fog light kinda fell off and I've passed 3 ncts with no mention of it :)
