Indicators not working
sconson
What Minis have you?: 1992 Mini Cooper
Modifications: Below were on the car when I bought it.
• Clarion sound system with speakers built into back shelve
• K&N air filter
• Roll cage
Post by sconson »
Hi lads,
indicators don't seem to be working altho the hazzards work fine, any suggestions as I can't really drive it without indicators!!
Cheers
MiniMe
Whats your location?: Galway
What Minis have you?: Sprite Spi
Modifications: Customised paint & interior. Gazadjust shocks
Post by MiniMe »
Could be a fuse; hazards run on a different circuit
Posted with TouchBB on my iPhone
Re: Indicators not working
I have the exact same issue. Hazards work fine, but not the indicators. Brake lights are also gone. I was thinking that the indicator stalk might be dodgy, but the horn works on it.
sconson
• K&N air filter
• Roll cage
Post by sconson »
Replacing the fuses tomorrow so fingers crossed!
Which set of fuses are the indicators?
just_st3v3n
Post by just_st3v3n »
antodeco wrote:I have the exact same issue. Hazards work fine, but not the indicators. Brake lights are also gone. I was thinking that the indicator stalk might be dodgy, but the horn works on it.
thats your fuse, the two of them are on the same fuse circuit.. check to see if its gone or could be the connections.
sconson wrote:Hi lads,
Cheers
as above you'll know if its a fuse if your brake lights dont work as they are on the same circuit.
if the fuse isnt gone check the connections on the fuse box. if everything seems fine there get back in the car..
stick your head under the right side of the steering wheel and there should be a little box (indicator flasher unit) that would be your culprit.. ya can get them in most motor factors for a few quid...
steven
edit
antodeco wrote:Which set of fuses are the indicators?
think its the second one from the top
some day....
Gav88
What Minis have you?: 89 mayfair,
91 city project!
Modifications: Stage 1kit, custom interior, bits and pieces, have a look
Post by Gav88 »
aAll of the above work and decide not to work in mine when they feel like it, tore out the dash to find some wires getting hot, think its a grounding issue, I'm sick of toying with a multi meter upside down, backwards and inside out :evil: . Anyone got a number for a good auto electrician in munster ?
just_st3v3n
Gav88 wrote:aAll of the above work and decide not to work in mine when they feel like it, tore out the dash to find some wires getting hot, think its a grounding issue, I'm sick of toying with a multi meter upside down, backwards and inside out :evil: . Anyone got a number for a good auto electrician in munster ?
faulty connections at the fusebox??
i ditched the original fusebox and got a 6 fuse one that uses the more modern spade fuses, problems solved :lol:
some day....
is u'r car an spi?? its fuse 10 in the fuse box but is u'r radio working?? they're on the same fuse
sconson
• K&N air filter
• Roll cage
Post by sconson »
steven
Replaced the Flasher unit and still no joy :evil:
daniel garry wrote:is u'r car an spi?? its fuse 10 in the fuse box but is u'r radio working?? they're on the same fuse
Not sure what spi stands for :? Its a 1992 Mini Cooper if that helps??
Radio works fine, what fuses do I replace and where can I find them?
single point injection, is ur car injected or has it got a carb??
sconson
• K&N air filter
• Roll cage
Post by sconson »
Injection as far as I know.
